Dell 197FPf
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Dell 197FPf
    Got this for $5. Guy said that it takes multiple tried to turn on. When I plugged it in it turned on by itself no problems. (i did not need to press power to turn on)...
    But, the button doesn't make it turn off. The power buttons doesn't do anything.
    I plan to take it apart and inspect for any loose connectors, bad caps, etc.
    But... there are no screws how do I take it apart? Thanks!
  • lcdman
    TinkerTech
    • Nov 2010
    • 232
    • U.S.A.
    Re: Dell 197FPf
    I could be wrong but, I think this model Dell should have those tool inserts along the bottom of the monitor like alot of the other "E" series Dell monitors. Such as Dell E172FPb,,c,f,s. Maybe the grey plastic button inside the bezel is broken and that is why you can't turn it or of via the switch? Otherwise have fun with your $5 project!
    Take Care,
    lcdman
    • shovenose
      Send Doge Memes
      • Aug 2010
      • 6575
      Re: Dell 197FPf
      Aha! Iget it! The front bezel comes off, then the plastic back comes off... Thanks!
      • shovenose
        Send Doge Memes
        • Aug 2010
        • 6575
        Re: Dell 197FPf
        Well, I think he lied to me. It has some liquid damage on the inside where the little front panel circuit board is. And the plastic looks like it was pried open before. However, I don't care. Why? Because it works just fine! I don't care if I can't turn it off... as long as it just stays on. Lol! And it matches my Dell 22" perfectly. Side by side they look great!
        • shovenose
          Send Doge Memes
          • Aug 2010
          • 6575
          Re: Dell 197FPf
          • masoksian
            Dell latitude e7470 not turn on .power buton on off and Run Power problem
            by masoksian
            I am dealing with the problem of turning on and off my Dell e7470 notebook.
            The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
            The system does not turn on, there is no post.
            I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
            The problem continues in the same way.
            I tried to turn on the Fn key, nothing came to the screen....
            02-15-2025, 12:08 PM
          • Bowline
            by Bowline
            06-11-2025, 10:13 AM
          • Naineesh1
            DELL inspiron 15-3515 GDM54 LA-L245P Won't turn on
            by Naineesh1
            I just recieved a working laptop for a quick dc port swap, i tested the laptop on battery it worked, tested dc port issue felt loose, so disassembled the laptop and removed battery connector, swapped the dc port, re-connected the battery connector, inserted dc pin, white led glowed up - stable, pressed power switch, but it didn't turn on, no fan spin and no display. just 1 white led that glows up, doesn't move to orange (charging), i check voltage (battery : 11.37v) (dc input port : 19.3v)(bios : 1.75), i am stumped, there is no shorting on board.
            Schematic diagram : bios chip volt...
            07-05-2025, 01:20 AM
          • javieromex
            Dell G15 5511 LA-K452P won't turn on
            by javieromex
            Hello, any help will be apprecited!
            • Model: Dell G15 5511
            • MB: LA-K452P
            • Issue: Won't turn on at all, no leds, no keyboard light, no fan spin, nothing happens when pressing power button. NOTHING.
            • Customer reported it was turned off and left plugged in during the night and thats it...
            • No signs of liquid damage or burned components.
            Link to Schematics -> https://www.badcaps.net/forum/troubl...la-k452p-gdp50
            I have checked so far:
            04-17-2025, 12:44 PM
          • Nagyesz
            Dell inspiron 13 5000 - Doesn't turn on, overheating
            by Nagyesz
            I have a Dell laptop with me, a DELL inspiron 13 5379. It doesn't turn on. After some investigation, I found that the charger is delivering 0-3V instead of 19.5V, and this voltage fluctuates constantly. Additionally, two ICs are overheating. I searched for these ICs, and it seems they are likely related to the issue of not having 19V.
            Should I inject voltage somewhere, or should I replace the ICs right away?
            So, PU4301 is overheating, and the surrounding area is hot, possibly just because of this IC.
            07-13-2024, 11:27 AM
