View sonic vx2250mw won’t turn on
  • Airtech_bli
    • Nov 2011
    View sonic vx2250mw won't turn on. I have check the switch
    to see if it was stuck I can hear the micro switch clicking, I checked
    the power cord it is good. I need to check the power/inverter board
    main/logic board to do that I need to open the case of the monitor with
    out breaking it can I get some help?
    Thank you
    Airtech_bli
  • retiredcaps
    • Apr 2010
    • 9271
    Re: View sonic vx2250mw won't turn on
    1) Pry it apart like this video
    http://www.youtube.com/watch?v=Ul5LhuCT1y8
    You will likely break a couple of tabs, but that is okay.
    2) Post pictures of all your boards using the manage attachments function with the following composition.
    https://www.badcaps.net/forum/showpo...94&postcount=1
    Do not post the images inline.
    --- begin sig file ---
    --- end sig file ---
    • insomniacno1
      Thinkpad L540, won't turn on unless I switch ram
      by insomniacno1
      This is a very weird problem and super annoying, so if someone who has experience with this, can explain why this is happening, then I will be grateful😁
      This happen usually when the laptop has been moved. from one room to another OFF charger for some hours, but has also happened when laptop has been shut down and left ON charger over night, and not moved :
      I turn on the laptop normally by pressing the power button briefly, then power comes on and Power LED and Fn LED turn ON/OFF constantly (no post and no beep codes)
      If I(and this is my only option at this point),...
      09-29-2025, 05:58 AM
      Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
      This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
      09-06-2024, 05:30 AM
    • ajc333
      Dell Precision 7710 - it can not be turn on and off with the switch
      by ajc333
      Hello.
      Markings on the board AAPB0 LA-C551P REV:4.0 (A03). The laptop came to the service with the fault of shutting down after a few minutes of load such as a game. It turned out that the smaller fan was damaged, a complete original cooling system from dell was ordered and from this time everything is back to normal. The problem, however, is the inability to turn on and off the laptop with the switch. On the switch board, the voltage drops from 3V to 0V when the switch is pressed.
      On the connector on the board (from the right side) I have the following voltages:
      n1. - 3V after...
      03-10-2023, 07:27 AM
    • Natob82
      Micro Momentary Push Switch?
      by Natob82
      Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
      12-21-2022, 05:22 AM
    • grimacelord
      NEC TurboExpress On/Off Power Switch Replacement Help
      by grimacelord
      I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
      I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
      I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
      11-09-2023, 09:49 AM
