ACER AL2416W - Screen goes off after 0.5 secs but light stays on power button
  • phillips321
    • Sep 2011
    • 9
    Hi guys i have an Acer AL2416W monitor. I have had the thing for probably the best part of 4 years and it's been great.
    Recently I have started to get a problem.
    When i provide power to the monitor i get a green acer logo pop up briefly then the screen turns off (the power button still has a green light on it).
    If i yank the power cable out and in a few times i can sometimes get the monitor to stay on but the issue has been getting worse.
    Once the monitor is on it stays on, it's just the initial turn on stage where it will switch off.
    I'm comfortable with a soldering iron (not a guru, just comfortable). I presume i will need to replace some parts. I have a local maplin store close to me.
    Any ideas on what i can check?
    Many thanks
    phillips321
  • phillips321
    • Sep 2011
    • 9
    Re: ACER AL2416W - Screen goes off after 0.5 secs but light stays on power button
    And the pics
    Pic1 - Looks like C34 is bulging bad out of the bottom and C36 has rust?
    Pic2 - Other side of board looks fine
    Pic3 - Close up of C34 bulge
    Pic4 - Close up of C34 bulge (other angle)
    • alexanna
      • Mar 2010
      • 1346
      You might try to get this moved to the monitor section, you will get grater response.
      Pictures of the power supply and inverter will help a lot, a close up photo of the entire power supply and inverter using managed attachments.
      I have had two, and there have been others that replacing the capacitors particularly on the inverter has solved the problem. If there is more than 1 fuse on the inverter they should also be checked.
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        Seconded, it looks like you only linked to thumbnails of your pics, which aren't very helpful. Crop/resize as close to 2000x2000 and upload using the attachments function.
        A working TV? How boring!
        • phillips321
          • Sep 2011
          • 9
          just updated the photo links.
          If a mod can move this to the correct forum area that would be much appreciated.
          • dood
            Deputy dood
            • Mar 2004
            • 2462
            Thread moved.
            That's an odd way to mount those caps.
            I'd replace any of those caps, whether they appear to be failed or not. C34,35,and 36 are all failed or failing. The rest likely aren't far behind.
            Ludicrous gibs!
            • phillips321
              • Sep 2011
              • 9
              Ok so i just ordered 10 caps:
              http://cgi.ebay.co.uk/ws/eBayISAPI.d...:X:RTQ:GB:1123
              Hopefully it'll be these that are causing the problem. Does it look as though i've order the correct caps? The ones on the board say 35v 100uF.
              P.s. Cheers for moving the thread
              • jetadm123
                • 2169
                Hard to tell, since the seller did not list the brand/series of the caps.
                • phillips321
                  • Sep 2011
                  • 9
                  Ok so what do you mean by brand/series? Like Nike/Addidas?
                  How will that make a difference? In quality? In efficiency?
                  Maybe before i fit them i should take some photos of them and list them up here, i bought these one's purely because of the "long life" description.
                  • Th3_uN1Qu3
                    Believe in
                    • Jul 2010
                    • 6031
                    Yeah, just that Nike and Adidas didn't make caps last time i checked.
                    In both... as in if you buy the right caps you won't have to replace them every year.
                    • serious_electron
                      Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
                      by serious_electron
                      Hello Everyone!
                      I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
                      06-28-2025, 02:57 PM
                      09-06-2024, 05:27 AM
                      Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                      This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                      09-07-2024, 05:00 AM
                      Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                      This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                      Acer Nitro Acer Nitro 5 Black Notebook 5 Specification for Upgrade or Repair
                      This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                      09-07-2024, 04:10 AM
