I have an Acer X241W with a backlight failing to come on.
Display works - I can see the OSD Menu when holding a flashlight to the screen, and it is responsive to menu/button controls.
Upon opening up the unit, I could tell it has been worked on. Replacement low ESR caps have been installed on both the power and logic boards, and the work looks good.
I pulled the inverter board and checked the transformers. They all appear to be in working order. No burns or heat marks visible and each measures the same resistance across each lead in each respective combination.
So I decided to power up the power board (Model AS08B360411) and take some readings from the 5v/12v/19v rail that powers the inverter. When switching the unit on and measuring voltages before the standby mode engages, this is what I came up with (see attached images and annotation on image #3).
There does appear to be heat discoloration on the front and back of the section of the board I'm dealing with, although I believe it is probably from an earlier failure, as no components appear to be damaged/burned.
Anyone care to help me troubleshoot this board?
Thanks,
SK
p.s. Entry #17 on the following page reports almost the same readings on the pins of a similar monitor: https://www.badcaps.net/forum/showth...ighlight=x241w
Thanks,
SK
