Gateway FPD2485W Issues
  • Gstepnick
    • Sep 2010
    Hello everyone. I apologize if I should not make a new post for this, as many of the symptoms of my problem were the same as found in this thread
    However, since the troubleshooting there moved past capacitor issue and into fuses, I figured I should start a new thread and inquire how exactly I should go about trying to fix it. I have not used this monitor for quite awhile now, since it has been out of commission, and didn't have the opportunity to try to fix it.
    The symptoms pointed towards a likely cap issue:
    At first, I had the issue when an input would be turned off, even if there was another active input, the monitor would get stuck trying to get input from the same place, and would then go into standby. When turned back on, it would try again instead of trying other inputs, and go into standby. This would repeat for an annoyingly long time, until it would finally choose the main input.
    This continued, and the monitor became less and less responsive when switching inputs and turning on. The Gateway splash screen persisted over whatever was on screen after being turned on (logo and black box around it, the rest of the screen had the proper image).
    Eventually, the monitor would simply not work. The soft menu buttons (which I've decided I really don't like very much) lit, but no image on the screen. I can't remember clearly, but I don't think there was an image at all (no backlight & no image). Obviously by then it was out of warranty, so I decided to crack it open and see what the issue might be. I looked around online and concluded that checking the capacitors was a pretty decent first step. Some of them don't look completely right, but I'm not entirely sure. I ordered a repair kit, although I'm not sure it came with everything that I need I've included some images, perhaps you guys can tell which don't look right better than myself. If I need to retake any of them, let me know, and I appreciate the assistance in advance!
    -The last image is of the caps I already have. Ideally I wouldn't have to order more, but if I need more, let me know what / which I'd be looking for.
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: Gateway FPD2485W Issues
    The images seem to have gone missing along the way. Please use the Manage Attachments function in Post Reply to upload them here, do not include them inline with your post.
    A working TV? How boring!
    • Gstepnick
      • Sep 2010
      Images (Imgur link, had issues uploading)
      • smason
        • 1652
        Don't apologize! Some of us much prefer 1 thread per monitor. There's a Samsung thread with 274 frigging posts in it
        Your photos aren't the best, but it looks like you definitely have some bloaters, even on the logic board.
        I'll bet if you replace them (many will recommend, and I always do, replace all of the electrolytics, 'cept the big mains one) you'll be good as new.
        One of the first monitors I did was a Gateway 2185, I recapped it, and it's been my main monitor for about a year now, still going strong. Best $7.00 monitor I've ever owned.
        • Gstepnick
          • Sep 2010
          I've been messing around with a multimeter to figure out which ones are definitely bad, and have narrowed it down, although some of them are questionable. I was going to use the ones I bought if they were enough to fix those, although it only came with the ones pictured. I'd need more if I were going to replace all of them (which I might end up doing)
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            A multimeter won't measure caps... You need an ESR meter for that. Provided the monitor still turns on, a multimeter will however help you see whether voltages are fluctuating on a particular rail. Fluctuating voltages + bloated caps = i think you know already what needs to be done.
            Please add your location in your profile so we can recommend a parts store in your area. If you're in the US you can support this site and buy from the badcaps.net online store.
            • ipman
              • Jul 2011
              • 159
              Increased ESR can sometimes be found indirectly, some caps are also loosing capacity. It's not generally true, and you cannot count 100% on that, but is as good as it gets whithout ESR meter.
              Also, some high-end multimeters can measure AC and DC components at the same time. An AC component too high indicate bad filtering.
              • Gstepnick
                • Sep 2010
                Do the physical dimensions of the replacements matter? There are a few that are taller than are available. Same specifications otherwise.
                • knoxrebel
                  • Oct 2009
                  • 168
                  Gstepnick make sure you see my previous thread about this monitor. I was able to get it working by replacing all the visibly bad caps and 1 voltage regulator.
                  • PlainBill
                    • Feb 2009
                    • 7034
                    The only significance of the dimensions is a matter of fit. If 10mm caps are touching one another, obviously a 12.5mm won't fit. If there is only enough room for caps less than 20mm high, a 25mm high cap won't do.
                    The usual recommendation is to replace ALL electrolytic caps with the exception of the large (typically 100 uF, 450 volt) one. In particular, some of the smaller electrolytic caps will fail without any obvious signs. Of course, if one ENJOYS taking their monitor apart to replace 2 or 3 caps every year...
                    If it hasn't already been noted, buying caps at Radio Shack is expensive, and (almost) a waste of time. They do not sell the ultra low ESR caps these power supplies require.
                    PlainBill
                      HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                      This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                      09-12-2024, 02:20 PM
                    • Jaime Morillo
                      Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                      by Jaime Morillo
                      Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                      The TV was stuck on the logo and I couldn't access the update menu.
                      I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                      The image result was good, but the image is inverted.
                      The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                      Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                      08-18-2025, 11:38 AM
                      HP ProBook 430 G6 + Image Load, Asset Tag & Testntag Notebook 400 Specification for Upgrade or Repair
                      This specification for the HP ProBook 430 G6 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load, Asset Tag & Testntag boardview and 430 G6 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                      09-06-2024, 10:56 AM
                      HP ProBook 450 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                      This specification for the HP ProBook 450 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load & Asset Tag boardview and 450 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                      HP ProBook 430 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                      This specification for the HP ProBook 430 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load & Asset Tag boardview and 430 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
