HP 1740 LCD Monitor 2 seconds to black
  • ntehicks
    • Mar 2011
    • 272
    I thought I would post this up here and ask if you think this would even be worth putting money into.
    The monitor when turned on will come up to the normal screen for about 2 seconds and then you hear a noise like HV shorting out and then the monitor goes black. Every capacitor including the 450v 100uf is buldging. Infact this large capacitor has black gunk coming out of the front. With the monitor only a 17" and as you can see in the pictures many parts of the circuit board is really dark. Looks like this thing has some warmth going on inside
  • PlainBill
    • Feb 2009
    • 7034
    Re: HP 1740 LCD Monitor 2 seconds to black
    It depends on what you feel your time is worth. Figure it will cost $12 -$15 for caps. If there is arcing at one of the CCFL leads a few drops of RTV or liquid electrical tape will fix that.
    PlainBill
    • George Ortiz
      • Oct 2009
      • 51
      This looks like the same power supply problem areas that I had on my L1740 that I had to repair. I replaced the caps (got mine from Digi-key Look up my L1740 thread). Turns
      out even after repairing the power supply the problem was that one set of CCFLs was burnt out. On another L1740 with the same power supply (this is a Phllips Power supply btw) problem, one set of CCFL's was burnt out. Definitely replace the bulging caps on the power supply and then check for the bad CCFL's.
      • PlainBill
        • Feb 2009
        • 7034
        George, how difficult was it to pull the CCFLs on your monitor? Would pulling them and examining them BEFORE replacing caps be practical?
        Off the top of my head, the caps would cost $12 - $15. A working monitor would be worth $50 - $60, so there is a good return on investment. A pair of CCFLs would up the cost to over $35, making the project impractical, in my opinion.
        PlainBill
        • George Ortiz
          • Oct 2009
          • 51
          If you have the power supply and logic board removed, disassembly of the lcd screen was not that hard. Also be carefull removing the lcd board that connects via mylar flat ribbon to the front of the lcd screen, I tore two when disaasembling the screen. I would definitely check the CCFL's first (with the Philips power supply board). There are two other companies that made the power supplies for this model of HP. Benq is one and the other I am not sure of. If ntehicks needs a repaired power supply/logic board combo, he can have one of mine. I have two of them sitting around. Just cover my shipping costs.
          • bomcla
            • Nov 2010
            • 16
            the pictures you posted, I thought I saw at least 3 swollen capacitors with the top (2 in the power supply board and a plate in the interface: If you did not already changed shall immediately, even if you have the opportunity to try the lamps is better. let us know!
            • Rick_1234
              LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
              by Rick_1234
              Good evening, gentlemen.
              I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
              To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
              https://drive.google.com/file/d/1L6S...ew?usp=sharing
              Things I tried
              - Bought a new AC adapter thinking that was the problem but the problem...
              06-22-2024, 04:44 PM
            • sew333
              Pc shutdown, monitor flickered with no signal after 10 seconds
              by sew333
              My pc:
              10850K stock 4800mhz stock Kraken X73 good temps
              2x16 GB DDR4 GSKILL 3000mhz XMP
              Seasonic Tx-850 Ultra Titanium
              Gigabyte Rtx 3090 Gaming OC
              Aorus Z490 Pro Gaming
              1 TB SSD
              4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
              Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
              Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
              Power...
              02-22-2022, 10:27 AM
            • keepread
              Dell monitor PSU vs Dell laptop PSU
              by keepread
              Hi there!
              Someone gave me their old monitor, it's Dell S2715ht.
              The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
              Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
              10-30-2025, 04:45 PM
            • valscu
              EIZO SW3031W monitor blue color instead of black
              by valscu
              I have an Eizo SX3031W monitor and after a period i had problems with the tcon board. I did reflow, it went well for a while after but the problems appeared again. The second reflow attempt was a failure, the tcon board stopped working. In the meantime, I bought a perfectly functional Samsung 305T monitor from which I took the tcon board and installed it in the Eizo monitor. Since I turned on the monitor, the blue color appeared in the background instead of black. And also in Windows, appears blue instead of black. I tried various settings from the monitor and driver settings but...
              08-10-2022, 02:08 PM
            • turmix
              AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
              by turmix
              Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
              The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
              At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
              During another reassembly, I made a mistake, and...
              01-29-2024, 03:48 AM
