Re: Dell 2407WFPb Monitor - Bad Cap
If the monitor doesn't work after replacing these caps, check the surface-mount fuse on the smallest PCB, the one containing two DRAM chips and a large square IC. It is blown on the bad monitor I have here. It is labelled F1 I think or something Fxxx.
You can buy very small micro pigtail fuses to replace it with. Not sure what amperage rating it is so I cannot be of help there. Someone here can probably help if it turns out to be bad. Just cut the leads of the new fuse a bit short, bend with pliers into a tight "U" so they fit snugly around the old fuse, and add new solder to each side, leaving the bad fuse in place. Other fuses might be bad, too.
Thanks for the thread, BTW, I am going to use this info to hopefully repair this one.
