Samsung 192n no backlights
  • smason
    • 1652
    Today's special, a decent looking 19" Samsung 192N
    I swapped a working 15" NEC Multisync for it.
    Owner said the backlights come on but no image displayed.
    I tested first, I get power led but no backlights. Hmmm.
    Disassembled, holy crap what a pain. CCFL connectors are covered in glue, as is the panel connector. Once I get that off and get the PS/inverter board out, it has one of those plastic protectors on it, took 3 hands and several 4 letter words to get it off.
    I spot 2 slightly bloated Capxons right off the bat, otherwise nothing obvious.
    There's some white crud on a SMD zener, but it wipes off and the zener looks ok.
    I'm pretty sure it's gonna be more than caps, but it's gonna need at least 2.
    I have the boards out of a 172n, looks very similar, so I'll have some parts including inverter transformers if needed.
    I replace the 4 1000 uf caps measure the transformers, and SMD fuse, reconnect and test.
    Looks good!
    Will do a full recap before re-assembly.
    Cap measurements:
    1000 @ 25 945uf .04ohm ESR
    1000 @25 960uf .03 ohm ESR
    1000@10 28uf 6.6ohm ESR
    1000@10 262uf 3.0ohm ESR
    09-07-2024, 05:50 AM
  • max789
    Samsung UE48H6410 replaced Mainboard but backlights doesnt go on
    by max789
    Hello, I have a problem with my Samsung UE48H6410SSXZG with the main board BN41-02156A and the power board BN44-00709A. Everything seemed like this, the TV could no longer be switched on, the standby LED always flashed 5x2 times. Backlight was off and no sound from TV. Also made the flashlight test and there was no picture.
    I made the following tests:
    1. Disconnected the main board from Power Board = backlight works.
    2. Connected the main board and disconnected the T-Con = backlights does not work.
    So I ordered a main board from Ebay also BN41-02156A but from...
    01-18-2024, 06:56 AM
  • caspian
    What Zener Diodes on a Linear Power Supply
    by caspian
    Dear members,
    I have a linear variable power supply with unknown brand name that I used for voltage injection.
    Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
    In addition, I discovered that its zener diodes are defective.
    I can replace the burned transistors.
    But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
    Therefore, I cannot replace the zener diodes.
    I do not want to test the zener diodes in a test circuit to discover their model or value.
    no schematics are available...
    05-26-2025, 12:38 PM
    09-06-2024, 11:40 PM
