Samsung Syncmaster 223bw, multiple attempts to start backlight.
+ More Options
Posts
  • robadob
    • Mar 2011
    • 3
    Ok so basically about a week ago, my monitors backlight started flickering for a few seconds when i first turned it on. This then turned into it flickering and failing to start up which then turned to turning on and failing aftre a couple of seconds before after about 4-5 attempts turning on and staying on. Then finally this morning it took about 2-3 minutes to get it to turn on and it made a few quiet sounds while doing so.
    I won't be able to test any parts until I'm back home on the 9th April but hopefully with your assistance i can diagnose and possibly even order some parts for when i get home.
    (I'm situated in the UK)
    So is anyone able to identify the fault or do you need to me to check anything?
  • Dgtech
    E. Technician
    • Apr 2009
    • 1462
    • Steeler
    Re: Samsung Syncmaster 223bw, multiple attempts to start backlight.
    GO TO SEARCH AND PUT IN "223bw" YOU WILL GET A MULTITUDE OF POSTS FOR THIS SET.
    • robadob
      • Mar 2011
      • 3
      So according to
      https://www.badcaps.net/forum/showth...ghlight=223bw#
      I'll need to open it up and identify the offending capcitors via them bulging or having stuff seeping out of them. I think.
      • Scenic
        o.O
        • Sep 2007
        • 2642
        open it up and do a roundhouse kick.. replace all the caps except the big 400-450V one with new low-esr ones as discussed in the 225BW thread.
        these monitors (223BW-226BW) are pretty much identical on the inside apart from some revision changes..
        • robadob
          • Mar 2011
          • 3
          Ok thanks
            09-07-2024, 05:50 AM
          • soopacrucial
            by soopacrucial
            Hi folks,
            10-29-2024, 02:40 PM
            09-06-2024, 11:40 PM
            09-06-2024, 08:40 PM
