Samsung Syncmaster 223bw, multiple attempts to start backlight.
  • robadob
    • Mar 2011
    Ok so basically about a week ago, my monitors backlight started flickering for a few seconds when i first turned it on. This then turned into it flickering and failing to start up which then turned to turning on and failing aftre a couple of seconds before after about 4-5 attempts turning on and staying on. Then finally this morning it took about 2-3 minutes to get it to turn on and it made a few quiet sounds while doing so.
    I won't be able to test any parts until I'm back home on the 9th April but hopefully with your assistance i can diagnose and possibly even order some parts for when i get home.
    (I'm situated in the UK)
    So is anyone able to identify the fault or do you need to me to check anything?
  • Dgtech
    E. Technician
    • Apr 2009
    • 1462
    • Steeler
    Re: Samsung Syncmaster 223bw, multiple attempts to start backlight.
    GO TO SEARCH AND PUT IN "223bw" YOU WILL GET A MULTITUDE OF POSTS FOR THIS SET.
    • robadob
      • Mar 2011
      So according to
      https://www.badcaps.net/forum/showth...ghlight=223bw#
      I'll need to open it up and identify the offending capcitors via them bulging or having stuff seeping out of them. I think.
      • Scenic
        o.O
        • Sep 2007
        • 2642
        open it up and do a roundhouse kick.. replace all the caps except the big 400-450V one with new low-esr ones as discussed in the 225BW thread.
        these monitors (223BW-226BW) are pretty much identical on the inside apart from some revision changes..
        • robadob
          • Mar 2011
          Ok thanks
            09-07-2024, 05:50 AM
          • soopacrucial
            Samsung Syncmaster 740BF repair
            by soopacrucial
            Hi folks,
            I'm new here and was wondering whether you might be kind enough to give me some advice on troubleshooting the following problem:
            Quite a few years ago now, a couple of years from new, my Samsung Syncmaster 740BF LCD monitor starting playing up by making a buzzing noise and then the display would go blank. I seem to remember the blue power led would also go off when this happened but that I'm not 100% sure of. By pressing the power button I do remember I could at first get it working again but eventually the problem would come back. At the time I had read about...
            10-29-2024, 02:40 PM
            09-06-2024, 11:40 PM
            09-06-2024, 08:40 PM
