Samsung Syncmaster 245B
  • RobGill
    • Jul 2011
    #61
    Re: Samsung Syncmaster 245B
    Resistors R805, 806 & 807 are glued together with white stuff on my board. (Well, its gone brown probably with heat but was probably white when new.)
    Any idea why, and will it matter if I don't use it when I replace one of the resistors later today?
    (Thanks BTW to everyone for the useful info here...)
    • PlainBill
      • Feb 2009
      • 7034
      The glue is usually to hold the resistors in place while other components are inserted. It's not necessary - and actually detrimental - for operation.
      PlainBill
      • ospi
        • Jul 2011
        #63
        I have the same problem as the OP. OS can detect the display, power led is on but backlight doesn't fire up. The glue between the resistor triplet RB80n had turned into neat black brownish gradient. One resistor was dead, others measured ok. Equally distributed 'thank you' for everyone posting in this thread, hopefully I can get it fixed tomorrow.
          09-07-2024, 05:50 AM
        • soopacrucial
          by soopacrucial
          Hi folks,
          10-29-2024, 02:40 PM
          09-06-2024, 11:40 PM
          09-06-2024, 08:40 PM
