SyncMaster 216BW CAPS
  • davethecrave
    • Nov 2010
    My SyncMaster has some obviously bad caps (820 uf 25v, capXon) and I need to replace them. From what I hear this is a common problem for people with this monitor. What I want to know is where the best place to buy caps is (price and quality). ALso, if there are any tips that anyone knows that will help me, they would be greatly appreciated. This is my first time doing something like this (have to buy an iron and solder). I was thinking a good iron for the job would be 30-40w, but i have no clue on solder (lead-free vs. regular). So please, somebody with advice let me know what to do and precautions to take.
    Thanks for the time and help,
    -David
  • De3rcr
    • Apr 2010
    • 94
    Re: SyncMaster 216BW CAPS
    Originally posted by davethecrave
    What I want to know is where the best place to buy caps is (price and quality).-David
    This thread has a list of the caps most people recommend here.
    https://www.badcaps.net/forum/showthread.php?t=2280
    Most people recommend Panasonic FM or FC
    Digikey is where I get mine, Mouser and Newark also(if in US).
    You can usually get replacement caps for about $10, using USPS as shipping method.
    • retiredcaps
      • Apr 2010
      • 9271
      1) Get a 40W iron and regular 60/40 solder.
      2) If you are in the USA, follow PlainBill's instructions on how to order Panasonic FM caps (use FC if FM is not in stock).
      https://www.badcaps.net/forum/showpo...33&postcount=2
      3) Replace ALL your caps except the main filter cap (the largest one lying on its side). Capacitors die from age, heat, and shoddy build quality. Capacitors DO NOT have to be visibly bloated in order to bad. They can be out of tolerance uF (a 1000uF measures 20uF) and/or have high ESR (ohm). A multimeter will be insufficient to test for ESR. For that you need an ESR tester which costs between $50 and $300.
      4) This site has an excellent written soldering tutorial. See
      https://www.badcaps.net/forum/showthread.php?t=485
      5) A good soldering video by Curious Inventor at
      http://www.youtube.com/watch?v=I_NU2ruzyc4
      --- begin sig file ---
      --- end sig file ---
      • davethecrave
        • Nov 2010
        Thank you for your help. I will let you know how things went when the project is all said and done. I appreciate your patience and respect towards newbs like me.
        -David
          by momaka
          03-12-2025, 03:42 PM
        • liquidzorch
          862D+ solder station iron out of control when fan on
          by liquidzorch
          Hello.
          I have a soldering station, 862D+, and every time the hot air gun is on, even if it is just cooling off, the soldering iron controller stops controlling. Let me explain what has happened so far, as it took a while to get to this.
          First, the switch that turns on the hot air gun started to fail, the light came on, but temp never rose, I would have to switch it multiple time to get the gun to start heating, this was due to the contact inside being carbonized. I opened the switch up, clean the contacts, and it would work fin for a while until carbonized again. So, I ordered a switch...
          06-09-2022, 08:49 PM
        • eryjus
          by eryjus
          05-10-2023, 11:21 AM
        • Paxman_Swede
          by Paxman_Swede
          Hello!
          01-14-2025, 09:51 AM
        • acedogblast
          by acedogblast
          11-02-2024, 05:13 PM
