Samsung 930B re-capped, no backlight
  • alexanna
    • Mar 2010
    • 1346
    #41
    Re: Samsung 930B re-capped, no backlight
    I am beginning to wonder if something may be wrong in the inverter section.
    With the logic board unplugged providing 3.3 volts to the on off pin causes the back lamps to come on but they resemble a Florissant light with a defective ballast flickering rapidly.
    • alexanna
      • Mar 2010
      • 1346
      #42
      Originally posted by jetadm123
      Out of curiosity, with the tail lamp connected, are the voltages on pins 3,4 and 6 of the DM0565R still steady?
      I will need to check that just a little later dinner calls
      • Mikeley
        ESR Man
        • Oct 2010
        • 41
        #43
        What readings did you get for each regulator? Last questions for tonight, did you have boards back in the metal chassis frame with all screws back in when you had the logic board connected and powered with problem present?
        Was the LCD and front panel also connected to the logic board at the time? Try with everything connected once more, if that was the case, remove the LCD panel connector, check 5V and 13V.
        Reconnect and remove front panel, remeasure voltage in order to eliminate each of these.
        • jetadm123
          • 2169
          #44
          Please disregard what I had asked for earlier. The bulb is drawing more current than the 13V output is capable of putting out, which accounts for the dim light.
          • leperinc
            • Jan 2011
            • 18
            #45
            Alexanna, I looked at your pic of the underside of the power supply board and I'm assuming U202 and U203 have been replaced because they have no obvious burns on them, U203 doesn't look like it's soldered correctly (or it could be the lighting.. )
            carry on...
            update: still waiting for my parts
            • alexanna
              • Mar 2010
              • 1346
              #46
              carry on...
              The problem really looks to be in the inverter area.
              I have removed the Fet with the questionable solder, those 4 pads are on the drain of the Fet and all 4 pads show continuity to each other. Any way I removed and reinstalled the FET so there are no globs.
              Something is happening the problem is getting worse, now with the logic board disconnected, the Fet that I just installed got so hot it melted the solder of the board. I am not finding any of the pads shorted to ground.
              I used some Fet's I Had in stock, They appear similar to me but the amperage is rated lower, I wonder if that could cause this problem?
              http://search.digikey.com/scripts/Dk...=FDS8958ACT-ND
              • Pyr0Beast
                • Feb 2009
                • 406
                #47
                Replace both fets ?
                Lower converter frequency.
                Dimm output.
                I found out that 20W flourescent lamps eat more power as they age, going more towards 25W ...
                • alexanna
                  • Mar 2010
                  • 1346
                  #48
                  Originally posted by Pyr0Beast
                  Replace both fets ?
                  Dimm output.
                  Both have been replaced,anybody have ideas on the replacments I used?
                  • alexanna
                    • Mar 2010
                    • 1346
                    #49
                    I going to call myself extremely lucky, I had a power supply from a Samsung 19W monitor that had a problem with the LCD panel, there are some noticeable differences with the circuitry. The mountings were the same and the pin voltages are the same on CN2.
                    And it's working, I would still like to figure what is wrong with the original INV/PS,But at least I can get it out of here and make room for another.
                    Al.
                    • Pyr0Beast
                      • Feb 2009
                      • 406
                      #50
                      I'd check both mosfets for both inverters. Would also check their driving transistors.
                      • leperinc
                        • Jan 2011
                        • 18
                        #51
                        The parts from China finally arrived! removing the dead chips was a bit easier than I expected. I didn't expect the chips to be glued to the board, however the chips were hot and the glue was fairly soft. Soldering the new ones on went well. We now have a backlight. It's alive! Another one saved from the landfill.
                        Jetadm123 and retiredcaps: thank you very much for your help with this. If you're ever in the Ottawa area I owe you a beverage of your choice!
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          #52
                          Glad the parts from China worked. I use ebay a lot for these types of purchases and have had good luck with it.
                          Good job on the repair.
                          --- begin sig file ---
                          --- end sig file ---
                          • jetadm123
                            • 2169
                            #53
                            Great work! Glad things worked out. It's too bad you had to go all the way out to china to get the parts!
                            • jamenlang
                              • Mar 2012
                              • 8
                              • usa
                              #54
                              I just inherited a 930b with this no backlight problem. I have attempted to repair LCD screens in the past by replacing NPN transistors, that worked for a few minutes. I would really like to be able to complete a repair and have the screen WORK, maybe with a little help I can get this screen working again. My power light is on solid, I thought that replacing the capacitors with a kit from ebay would fix this. I replaced every cap with matching spec'd caps except for the 450v 100µf, (the kit didn't come with one). I tested the caps to the best of my ability, put my multimeter leads on them and they charged up. The two IC's labeled u202 and u203 aren't melted or exploded. I don't see any burns on the board. I can provide any test results that I can take down with a multimeter if someone can suggest what to check first.
                              • Jasgriff
                                • Feb 2012
                                • 578
                                Some really clear pictures of the top and bottom of both boards would be fantastic as this would allow us to guide you in the right direction.
                                When you say there is no backlight at all do you not even get a flash of backlight when you turn it on? Or does it come on for 2 seconds then go off?
                                Using a flash light on the screen you should be able to see a very faint image. Can you try this?
                                Fixed so far : 1 Home cinema system, 16 LCD Monitors, 4 LCD TV's
                                How to resize your pictures guide click HERE
                                Retiredcaps Ideal post example click HERE
                                • jamenlang
                                  • Mar 2012
                                  • 8
                                  • usa
                                  #56
                                  The LCD part is working, i saw the windows logo when i hooked it up. the backlight does not come on at all.
                                  • jamenlang
                                    • Mar 2012
                                    • 8
                                    • usa
                                    #57
                                    additional pictures of the LCD driver board
                                    • jetadm123
                                      • 2169
                                      #58
                                      See post #2 of this thread. Use the 200 ohm setting on your meter.
                                      • jamenlang
                                        • Mar 2012
                                        • 8
                                        • usa
                                        #59
                                        Should i test these on the board or take them off? should i test it with power applied /turned on?
                                        I disconnected the logic board and applied 3.3v to the on/off pin on CN2 and the backlights stayed off. does that rule out the logic board?
                                        • jetadm123
                                          • 2169
                                          #60
                                          NEVER take resistance readings with power on. For now, go ahead and test them on the board.
                                            09-07-2024, 05:50 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
                                            Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 06:20 PM
