Samsung 225bw flashing power button
  • Bolus
    • 7
    Hi There,
    My Samsung 225bw won't turn on. The power button just starts flashing fast. After about 30 min it seems to go on, but just for a moment, and without backlight. I can see a screen "auto adjustment" popping up every second or so.
    I guess it has something to do with the backlight inverter board. Do you guys agree? Could it be similar to this problem / these problems:
    https://www.badcaps.net/forum/showthread.php?t=6930
    Do you guys advise me to replace the same caps described in that topic? Thanks!
  • alexanna
    • Mar 2010
    • 1346
    Re: Samsung 225bw flashing power button
    Defiantly need some photos, Use managed attachments a good overall high quality shots straight down with no flash of the front and back of the boards, as close to the 2000x2000 pixel limit as possible
    It defiantly sounds like a capacitor problem, don't forget about the small usually around 50v and under 100uf caps that are in the area of the SMPS coil
    Al.
    • Bolus
      • 7
      Hi Alexanna,
      Thanks for your reply, see the screenshots attached. Here's some more info on the caps I found:
      3 x capxon 330uF 25v p640 vent GL 105° 12mm x 10mm (height x diameter).
      2 x capxon 820uF 25v c650 vent GL 105° 20mm x 10mm
      1 x capxon 47uF 50v c646 vent GL 105° 10mm x 5mm
      1 x capxon 150uF 450v c640 vent GL 105° 40mm x 20mm
      I understand that last one doesn't break that easily, so should I replace the rest?
      • PlainBill
        • Feb 2009
        • 7034
        Originally posted by Bolus
        Hi Alexanna,
        I prefer 'fail' to 'break', but you are correct. The 450Volt caps are usually good. Replace the other six with name brand, low ESR, 105°C caps such as Panasonic FMs.
        PlainBill
          09-07-2024, 05:50 AM
          09-06-2024, 11:40 PM
          09-06-2024, 08:40 PM
          Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
          This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
          09-06-2024, 06:20 PM
