Planar PL1700-BK - backlights go out
  • De3rcr
    replied
    Re: Planar PL1700-BK - backlights go out
    Sorry,
    J906 far right
    J903 far left
    Yes, and J903 comes on but not as bright as J904
  • retiredcaps
    replied
    And just to confirm, all the ccfls light up (when switched around) except when plugged into the "far right" connector?
  • retiredcaps
    replied
    Originally posted by De3rcr
    OK,
    Taking the middle lights and pluging them into the outer sockets, the left one came on really dim and then shut off and the right one didn't come on at all.
    Okay, just going forward and to make it easier to trace and follow, the far right is which J connector? J903, J904, J905 or J906?
  • De3rcr
    replied
    Originally posted by retiredcaps
    Okay, I guess the next step is to see if it is the ccfl's or the circuitry that is driving them.
    So plug the "working" middle ccfl into the far left. Then try the "working" middle ccfl into the far right.
    Report the results.
    OK,
    Taking the middle lights and pluging them into the outer sockets, the left(J903) one came on really dim and then shut off and the right(J906) one didn't come on at all. I plugged the outer lights into the inner sockets and they came on bright and then shut off. So when the either light is plugged into the inner sockets(good ones I hope) they all come on bright and then shut off.
    I didn't know you could switch the lights around like that(add that to my troubleshooting notebook).
  • retiredcaps
    replied
    OK,
    checked the backlights and if you look at my first pic the connectors on the far left and far right don't show any light, but the middle 2 give "2 secs to black" so I guessing I need to order some cclf's.
    Report the results.
  • De3rcr
    replied
    Before ordering anything, give us a few hours to digest the results and study the OZ960 datasheet.
    Additionally, you may not need new ccfls. It could be the ccfl wiring that is at fault.
    I looked at that datasheet, I can't even fit that in my mouth let onlone digest it. I was just looking for ccfl's, but it's a topploy panel they look hard to find.
  • retiredcaps
    replied
    OK,
    checked the backlights and if you look at my first pic the connectors on the far left and far right don't show any light, but the middle 2 give "2 secs to black" so I guessing I need to order some cclf's. But I can check that chip if needed.
  • uligli
    replied
    Great photos. I'm jealous that I can see grass in the background. Here I just finished shoveling snow and it is piled about 2 feet on one side. Anyone still playing Beach Volleyball on Daytona Beach?
    That remembers me back in the 90's when i rent a volleyball Nes game to play
  • De3rcr
    replied
    This section will probably make it into rev 0.3 of the guide, but right now for those without a spare or good ccfl, here it is.
    === snip ===
    Pay ATTENTION as there is a VERY HIGH VOLTAGE (600V to 1000V)! As a safety precaution, it might help to have someone around when you are doing this if something screws up.
    Alternatively, if you do not have a spare CCFL, try this test for a completely dead non working CCFL.
    a) TURN POWER OFF and unplug the monitor and wait 1 minute
    b) disconnect all CCFLs expect #1
    c) plug in monitor and turn monitor on - note if "2 seconds to black" occurs
    d) TURN POWER OFF and unplug the monitor and wait 1 minute
    e) disconnect all CCFLs expect #2
    f) plug in monitor and turn monitor on - note if "2 seconds to black" occurs
    g) TURN POWER OFF and unplug the monitor and wait 1 minute
    h) disconnect all CCFLs expect #3
    i) plug in monitor and turn monitor on - note if "2 seconds to black" occurs
    j) TURN POWER OFF and unplug the monitor and wait 1 minute
    k) disconnect all CCFLs expect #4
    l) plug in monitor and turn monitor on - note if "2 seconds to black" occurs
    If one of the CCFLs does not show "2 seconds to black", it is likely physically damaged (cracked) or the wiring is completely broken to it. Take out that CCFL and inspect it. If all 4 CCFLs do show "2 seconds to black", one or more can still be bad. This test only tests for a completely dead CCFL or completely broken wiring.
    Replacing a CCFL is a delicate operation. See "Lamp Soldering Tutorial" at http://ccflwarehouse.com/lasotu.html to see what steps are involved.
    OK,
  • retiredcaps
    replied
    BTW, the test results in post #17 is highly dependent on the inverter controller IC.
    I haven't looked through OZ960, but having just one ccfl connected may not be a valid test.
    Thanks to alexanna for pointing this out to me.
  • retiredcaps
    replied
    The inverter controller chip is OZ960. Here is the datasheet.
    We may need to take measurements later? Note the pins are very close to each other and caution is needed when measuring voltage as it easy to short something out.
  • retiredcaps
    replied
    === snip ===
  • retiredcaps
    replied
    dmm set on 2k
    Okay, that explains the 0. Your multimeter is probably showing 0.x ohm, but the resolution says it is 0. If you remeasure the 0 ohm reading with a 200 ohm scale, it will probably show 0.x ohm.
  • De3rcr
    replied
    dmm set on 2k
  • retiredcaps
    replied
    OK, I used the white dot on the transformer as pin 1
    1-2=open 2-3=0 3-4=open 4-5=open 5-6=open 6-7=0
    1-3=open 2-4=open 3-5=open 4-6=open 5-7=open 6-8=open
    1-4=open 2-5=open 3-6=0 4-7=open 5-8=open
    1-5=.581 2-6=0 3-7=0 4-8=.581
    1-6=open 2-7=0 3-8=open
    1-7=open 2-8=open
    1-8=open
    7-8=open
    hope this is what you needed
    What scale did you use on your multimeter?
    The 1-5 and 4-8 reading of .581 suggest the secondaries are okay.
    I have another test for you to try since you do not have another or spare ccfl. I'll post the instructions in a new post below.
  • De3rcr
    replied
    Okay, list the readings that you are getting when measuring the inverter transformer T901. We will interpret them.
    1-2=open
    1-3=open
    1-4=open
    1-5=.581
    1-6=open
    1-7=open
    1-8=open
    2-3=0
    2-4=open
    2-5=open
    2-6=0
    2-7=0
    2-8=open
    3-4=open
    3-5=open
    3-6=0
    3-7=0
    3-8=open
    4-5=open
    4-6=open
    4-7=open
    4-8=.581
    5-6=open
    5-7=open
    5-8=open
    6-7=0
    6-8=open
    7-8=open
  • retiredcaps
    replied
    Unfortunately I don't have any spare parts to check the ccfl's. I was hoping to maybe track it to the inverter. I'm trying to follow retiredcaps "2 secs to black" post, but I'm not sure I'm taking the right readings with the dmm.
  • De3rcr
    replied
    What about the cooling fan? Backlights on for 30 seconds seems more like thermal related to me.
    Tried cooling the board, that doesn't keep the lights on any longer. But if I unplug it then plug it back in the lights stay on for about 5 or 6 seconds.
  • retiredcaps
    replied
  • De3rcr
    replied
    Originally posted by alexanna
    I do not see where you tried substituted one or two good ccfls to see if the back lights will stay on.
    The flickering you mention makes me wonder if a ccfl may be causing your problem.
    Al.
    HP Elite Elite 7100 Microtower PC Elite 7100 i3-530 Specification for Upgrade or Repair
    This specification for the HP Elite Elite 7100 Microtower PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Elite 7100 Microtower PC boardview and Elite Elite 7100 Microtower PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
    09-12-2024, 03:44 PM
    HP Elite Elite 7200 MT Elite 7200 i5-2400 Specification for Upgrade or Repair
    This specification for the HP Elite Elite 7200 MT can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Elite 7200 MT boardview and Elite Elite 7200 MT schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
    HP Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) Compaq Elite 8000 E5500 Specification for Upgrade or Repair
    This specification for the HP Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) boardview and Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request...
    HP Elite Elite Slice Elite i5-6500T Specification for Upgrade or Repair
    This specification for the HP Elite Elite Slice can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Elite Slice boardview and Elite Elite Slice schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
    HP Elite Elite Slice Elite i3-6100T Specification for Upgrade or Repair
