Re: Samsung 2233sw '2sec to black'. Need guidance please.
Ok managed to re-soldered the transformer & measure the resistance
- on T301 (out-of-circuit)
: P1 = open to all
: P2 = 0.3ohms to P3, open to the rest,
: P3 = 0.3ohms to P3, open to the rest,
: P4 = open to all
: S1 to S2 = 904ohms,
: S3 to S4 = 981ohms
comparing to T301 (in-circuit)
: P1 =open to all
: P2 =1.2ohms to P3, increasing to P4, open to the rest,
: P3 =1.2ohms to P2, increasing to P4, open to the rest,
: P4 =increasing to P2, P3
: S1 to S2 =897ohms,
: S3 to S4 =initially 1500-1520ohms but drops to 943ohms after re-testing it again & again
: S1&S2 to S3&S4 = 191k ohms
Any thoughts?
So currently, on the board now are the replaced 13V caps (820uf) with 1000uf and it is without Transformer T301..
Yes, 'Sawasdee Krab' is greeting in Thai language.
While [backlight on] and you've got 12.2V, the temp. of D107 is just warm or too hot?
if it too hot, maybe voltage drop by overload in your CCFLs drive circuit.
if not, the 13.8V supply has defected somewhere.
just guess.Leave a comment:
FYI, i did further measure some other points near the secondaries (see attached), hope i did the right thing
[backlight on > backlight off-power led on]
V1 = 3.7V > 0V
V2, V3, V4,V5 = 0V > 0V
V6 = 0V! > 0V
I am a bit puzzled by this, why V6 is not reading the same as V1?.. hhmm.. Is it indicating transformer problem or circuit on that side of the transformer?..Leave a comment:
* retiredcaps & POM_MJ ('sawadee krap', fellow Asian), I manage to swap the three caps 820uf 25v (one at a time) with three caps 1000uf 25V Panasonic FM (12.5x20mm) & here are the result of the voltage measurement taken at middle pin of the diode (D107)
[backlight on > backlight off-power led on > all off but power plugged]
= 1st cap changed - 12.2V > 14.18V > 13.43V
= 2nd & 3rd cap changed - same as above ...
this is what i can afford to update as of now,
*Al, nope. I did try to leave it for about 1 min but it did the 2sec-to-black twice only.. One during start-up & the second one 20sec later.. After that couldn't detect anymore 2sec-to-black..
V1 = 3.7V > 0V
V6 = 0V! > 0V
*Rtech, thanks for sharing.. i think swapping caps still gives me 12.2V at backlight on, which i kinda belief caps are not causing this problem.. anyway, if you guys think otherwise, i am open to all ideas..
*PlainBill, sorry i could not desolder & measure the transformer yet,, The 'Queen' is having her shopping session & i'm stuck with my little rascals at home....I will try to do it in a few hours time..
I have noticed in other Monitors where there are Diodes in the Main Tmfr secondary,and not just Schottky diodes,to produce the 5v and 12v etc etc, that without a load the voltage does look unstable, but is fine on load.I would not concern myself with that at the moment.Leave a comment:
, I should do according to retiredcaps's recommendation first.
Caps may be fail even they're look good, and I guess they're already failed.Leave a comment:
hey guys, thanks for all your inputs. I will try to clarify/answer all the queries here. If I am not clear enough in my explanation or missout something, do ask more..
<SNIP>
Next, I should be de-soldering the transfomer & measure resistance again right?. What kind of resistance you guys suspect I should be getting?..
Several people have mentioned that the backlights coming back on after the 'two seconds to black' is unusual. One possibile explanation is the BD9893F contains an over-temperature shut down circuit.
PlainBillLeave a comment:
With LCD plugged in and power OFF, measure the diode (just next to R105) for DC V. The middle pin should be where the red probe goes and a ground screw for the black probe. It should read a steady 14.xy DC V.
If it is steady, I suggest replacing the 820uF 25V caps to see if that solves the problem. As a test, you can use anything handy if you don't have the proper low ESR caps. Even 1000uF 25V as a temp test should work? You cn replace them 1 at a time or all 3. I would do 1 at a time, but that is me trying to find "root" cause.
My suspicion is that 12.2V is too low.
If that works, replace all the caps afterwards.Leave a comment:
You say,
“If i leave the monitor on longer, 20 sec later the backlight will lit up again for about 2sec... then off.”
Will the monitor continue to do this over and over if you leave it plugged in?
Al.Leave a comment:
* CCFL - yes, shovenose. I did swap the CCFL with another panel. Same result.
* U202 (Dual channel Mode FET - STU312D) - jetadm123, using DMM set at 200, I cannot detect any shorting in between the pins. thanks for the info about the output voltage of the transformer.
* retiredcaps, noted on the warning. I certainly do not want any incident or accident to happen here. Yes, i feel its odd as well that if i leave it on a little while longer the backlight light-up then 2sec to black again. As for the transformer S3 to S4 resistance, initial reading when i opened it up was 1500-1520ohms, AFTER i did all the voltage measurements i measured it again & it drops to 943ohms. Now, after overnight, it is still steady at 940+ohms.
For the 13V, what i mean by unstable is that at backlight on, it reads 12.2V but when off it fluctuates between 14.19-14.90V. Not forgetting the caps, I have labelled the top side pix (thanks for the compliment, takes me a hell lot of hours waiting for the right sunshine angle to take them), kindly see below
Cap A - don't know what brand, dark blue color, what i can see is W0C PET, rating hidden below, 4x11 (estimated mm as i am using ruler, not calliper)
Cap B - Samyoung, NXB 330uf 10V, 7x10
Cap C - Samyoung, NXH 1000uf 10V, 10x12
Cap D - Samyoung, NXB 820uf 25V, 10x20
Cap E - don't know what brand, dark blue color, what i can see is WF W9C PET, 47uf 50V, 6x10
add: oops i just noticed while typing that i missed C116, i think its the same size with C114 (Cap A) but light blue in color.
* PlainBill, thanks for sharing the information on the caps.. $0.10 certainly wouldn't justify cracking open the LCD again.. better be safe, rather than.... having my fingernails bruised again..
Next, I should be de-soldering the transfomer & measure resistance again right?. What kind of resistance you guys suspect I should be getting?..Last edited by newbie1; 11-18-2010, 07:55 PM.Leave a comment:
16V would be fine, but it doesn't leave much "headroom" if the voltage were to momentarily go higher than the "desired" 13V.
I don't think there is a correct answer here. I think it depends on the original design criteria and how conservative the designers are in choosing their tolerances.Leave a comment:
@retiredcaps: why did you say that the 13v caps should be 25v rated at minimum? 16v caps would be fine, right?Leave a comment:
- on T301 (in-circuit)
Plugged & measured Voltages = backlight on (off)
- CN2
13V = 12.2V (14.19) both unstable
5V = 5.2V (5.21V) both stable
3V = 3.27 (3.27) both stable
- on T301
: S1 & S2 - Over volt (almost busted my DMM again)
: S3 & S4 - 6.2-6.5V?!!
On the 13V rail, please clarify what you mean by unstable? Does the voltage drop steadily or flucutate all over the place? What caps are on the 13V rail? They should be the caps that are rated 25V and higher.
PS. Great clear focused pics.Leave a comment:
also, what brand(s) are those caps. those yellow guys (or gals) look an awful lot like the "yc" and identical "fuhjyyus" (so same copmany i guess) that were completely bad. thanks...
and yes if they are a crap brand i may have you replace the mLeave a comment:
Hello! I'm guessing that U202 is a duo mosfet (?) that is used to drive the inverter transformer. Try checking it for shorts.
Don't try measuring the inverter voltage output (approx 700-900VAC).
Odd transformer readings. You may have to remove it from the board and retest S1&S2, S3&S4.Last edited by jetadm123; 11-18-2010, 10:40 AM.Leave a comment:
Hi guys,
& another one comes along..
Symptom/Problem
-2sec to black. Image visible if using torch light.
-If i leave the monitor on longer, 20 sec later the backlight will lit up again for about 2sec... then off.
-Power LED steady blue
Description/what's been done.. or not
- Age around 2-3years, But it is an export set so no warranty.
- No schematics at hand
- Have not replaced all caps because they all 'look' to be super fine. But will replace them if advised to do so.
- Use another panel (my 'dead' HP f1905 and working hp w20) to test ccfl (subtitute them one at a time or all at once), but still 2sec to black result.
Unplugged & measured resistances
- no short in between pins of D101(in circuit) & D107 (out of circuit)
- U201 BD9893F Pin 16 (Vcc) not shorted to Pin 6 (Gnd)
: P1 =open to all
: P4 =increasing until max to P2, P3
- across Big cap = 330V (330V)
- CN2
- U201 BD9893F
Pin 16 (VCC) = 11.01 (10.9)
Pin 9 (Comp) = 0.61 (0.51)
- on T301
So 1 side of the transformer is reading less voltage than the other.. So is this transformer faulty & need to be replaced?.
Or are there other components or test points that i missed out?..
Am i troubleshooting it correctly?..
Hope the experts here can guide me along.. again thanks..Last edited by newbie1; 11-18-2010, 09:36 AM.Tags: None
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
This specification for the Samsung Galaxy Book Ion NP950XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ boardview and NP950XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 11:40 PM
This specification for the Samsung Galaxy Book Ion NP930XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ boardview and NP930XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 11:40 PM
This specification for the Samsung Galaxy Book Ion NP950XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ boardview and NP950XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 08:40 PM
This specification for the Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-K01DE boardview and NP950XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-06-2024, 06:20 PM
- Loading...
