HP E233 display HDMI no input
  • rp748
    • Aug 2023
    • 3
    • Israel
    Hi
    The display is working great except for the HDMI. VGA, DisplayPort is fine.
    i have tried several cables and sources with no luck.
    Board number is 715G8912- but i didn't find its schematic anywhere.
    The main chip is RTD2526FR which i didn't find its datasheet as well.
    Main board looks fine without any blown components or soldering issues.
    When an HDMI source is connected the screen goes blank for a few seconds and then it says, "HDMI is inactive" and enters to sleep mode.
    Tested Components:
    HDMI connector - pin 19(HPD) show 2.4v without hdmi cable, 5v with cable.
    JA - 2.4v, 5v in, and diode check forward polarity=0.6v and "OL" the other way around.
    C31RH - i guess it is an ESD protection IC, all I/O's shows 0.6v to GND pin and "OL" in reverse polarity and "OL" to Vcc pin
    24C02 - EEPROM, i do not own a scope so i do not know how to test it except for measuring voltage which demonstrates 5v to Vcc, SCL,SDA pins.
    attaches are board pics
    any help is most appreciated.
    The main reason for fixing it is learning so buying a new board is non relevant.
    tx
    Ran
  • rp748
    • Aug 2023
    • 3
    • Israel
    Re: HP E233 display HDMI no input
    attach pic of PCB with tested component p/n
    • bronxgsi
      • Nov 2023
      • Spain
      Hi!, I have the same problem. Did you solve it without replacing the board?
      Thanks in advance!
      • CapLeaker
        Leaking Member
        • 8118
        Thanks in advance!
        Welcome to badcaps!
        Unfortunately there isn't enough information given. Try a different cable, wiggling the connector etc. Does the computer recognize the screen, or is it dead as a rock? Are there any loose /damaged pins on the HDMI connector on the board? Does the monitor turn on at all?
        • bronxgsi
          • Nov 2023
          • Spain
          Welcome to badcaps!
          Thank you very much for your answer.
          I've already tried the cable in another HP monitor (24fh) and it works. It says no input but the laptop seems to recognize the monitor. OSD is working. I tried with Display port and HDMI.
          • CapLeaker
            Leaking Member
            • 8118
            If it isn’t the cable nor any other inputs work, it’s either the firmware, EDID, or the main CPU.
              HP EliteBook x360 1040 G5 + EliteDisplay E233 Hybrid (2-in-1) Specification for Upgrade or Repair
              This specification for the HP EliteBook x360 1040 G5 + EliteDisplay E233 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1040 G5 + EliteDisplay E233 boardview and 1040 G5 + EliteDisplay E233 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
              09-06-2024, 08:50 AM
              HP EliteBook 830 G5 + EliteDisplay E233 Notebook 800 Specification for Upgrade or Repair
              This specification for the HP EliteBook 830 G5 + EliteDisplay E233 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 830 G5 + EliteDisplay E233 boardview and 830 G5 + EliteDisplay E233 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
              09-06-2024, 08:47 AM
              HP EliteBook x360 1030 G3 + EliteDisplay E233 Hybrid (2-in-1) Specification for Upgrade or Repair
              This specification for the HP EliteBook x360 1030 G3 + EliteDisplay E233 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1030 G3 + EliteDisplay E233 boardview and 1030 G3 + EliteDisplay E233 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
