benq fp767 problem 17 inch
  • gasan
    • Sep 2010
    • 26
    hey guys i have a problem with my screen , when i attach my ac cable to the wall the blue button turn on without any signal comes to the screen even at startup there are no benq logo so guys i need help??????????
  • PlainBill
    • Feb 2009
    • 7034
    Re: benq fp767 problem 17 inch
    Yes you do. Do you want an instant diagnosis based on very little information, or would you like to approach the problem systematically?
    If you want to jump in and throw money at the problem, order REPAIR KIT E172FPB E173FPB FP72G FP731 - 2SC5707 C5707 from an eBay seller and install it.
    If you want to take an intelligent approach, open the monitor up, take pictures (top and bottom) of the power supply / inverter and ATTACH them to your next post. See the link in my signature for instructions.
    PlainBill
    • gasan
      • Sep 2010
      • 26
      thanks for the reply , i have been looked at the powersupply there are no blown capacitors some one told me that the logic card is gone , so i want to diagonse the main reason of the problem can you help me please (step by step )
      • gasan
        • Sep 2010
        • 26
        there are no colors on the screen its blank , the whole monitor not working execpt the button blue lamp (on /off button) even there is no electric sound came from the flurecents !!!!!!!!!!!!!!!!11
        • smason
          • 1652
          Some questions:
          Do you own a multi-meter, and do you know how to use it?
          Can you solder?
          If the answer to all of those was yes, then we can probably help you.
          You can't always see bad capacitors, blown transistors and blown fuses just by looking at them. The chances of the problem being the logic board are about 1% 99% more likely is the power supply/inverter circuitry.
          So if you can answer the questions, post good clear photos of the top and bottom of the boards, and mabe even hint at what part of the world you're in, we can move forward.
          • gasan
            • Sep 2010
            • 26
            yes i can do all the things that you mentioned , oh yes i am ready i have multimeter and solder ...............
            • smason
              • 1652
              Excellent. Next step, post some photos, and we'll give you some tips on what to test.
              I'm betting at least 1 bad transistor and pico fuse.
              • PlainBill
                • Feb 2009
                • 7034
                I'll see that and raise you two bloated caps.
                PlainBill
                • gasan
                  • Sep 2010
                  • 26
                  ok i will upload pics of the power supply and logic card thanks guys
                  • gasan
                    • Sep 2010
                    • 26
                    here are the pics of the powersupply and the logic board
                    powersupply=no model=etl-xpc-801 1.6mm
                    • gasan
                      • Sep 2010
                      • 26
                      where are you guyssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssss
                      • PlainBill
                        • Feb 2009
                        • 7034
                        The agreement I have with Topcat is that I am allowed to have a life. Taking most of a day to upload the pictures, uploading useless pictures, then expecting help within 18 minutes suggests you should get one too.
                        Q739, Q740, Q743, Q751, Q759, Q760, PF751. Test them and replace any that are bad.
                        PlainBill
                        • gasan
                          • Sep 2010
                          • 26
                          how to test them on the multimeter and where to put the multimeter (where it should be on ohm or volt .............) ?????????????
                          • smason
                            • 1652
                            <facepalm>
                            I think you need to re-read a few posts. We said "Good CLEAR pictures" and I asked do you have a multi-meter and know how to use it....
                            Luckily PlainBills newly modified eyes could magically read the component designations.
                            And seriously... 4:43 AM (MDT) and you're impatient for responses? Oy!
                            We'll help you, but really, try to help us help you.....
                            • gasan
                              • Sep 2010
                              • 26
                              ok guys i looked at my screen and see that there is a signal came to the screen (benq) logo and the windows xp) but without light mybe the problem with the power supply or the lamps ??
                              • smason
                                • 1652
                                Put your meter on the diode test setting, then test each transistor.
                                Red on base black on collector
                                Red on base black on emitter
                                Red on collector black on emitter
                                then reverse red and black and repeat.
                                You should see a reading between approximately .400 to .800 in one direction, and open in the other.
                                I suspect you'll see at least one that's shorted. Also test the fuse. If one of the transistors shorted it will likely have taken out the fuse.
                                • PlainBill
                                  • Feb 2009
                                  • 7034
                                  Probably also a good idea to mention resoldering the transformers. Several reminders may be necessary...
                                  PlainBill
                                  • smason
                                    • 1652
                                    PlainBill
                                    Yes was going to get to that in a seperate post.
                                    Some people (like some of my co-workers :slap: ) when sent an email with 2 questions, always seem to only answer 1.
                                    If you send each question in a seperate email, they magically get answered.
                                    Kinda like when you post "please post pictures, AND tell us where you are"
                                    you'll never find out where they are </hint>
                                    • smason
                                      • 1652
                                      Yes. The transistors and fuse Plain Bill listed are all involved in the inverter circuit, which is responsible for powering the lamps.
                                      • gasan
                                        • Sep 2010
                                        • 26
                                        ok q759+ q760 + q739+q740 gave me the same reading !!!! mybe its high voltage capacitors (blue). thank you guys
                                        any suggetions?????
                                          HP ZBook Firefly 16 inch G10 Notebook Specification for Upgrade or Repair
                                          This specification for the HP ZBook Firefly 16 inch G10 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 inch G10 boardview and 16 inch G10 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-07-2024, 07:20 AM
                                          09-07-2024, 07:19 AM
                                          09-07-2024, 07:12 AM
