Samsung SyncMaster 510N-Check Signal Cable
  • tama4tama
    • Nov 2006
    • 56
    I have this Samsung SyncMaster 510N which is giving me some hard time.
    The problem is when there is signal cable to the CPU it would be blank and nothing on the screen, but without signal cable to the CPU it will give “Check Signal Cable” The backlight works when there is no cable to the CPU, so I think inverter and the power supply unit is ok.
    Any suggestions
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Samsung SyncMaster 510N-Check Signal Cable
    Originally posted by tama4tama
    Any suggestions
    Did you try a different source and different VGA cable?
    --- begin sig file ---
    --- end sig file ---
    • tama4tama
      • Nov 2006
      • 56
      Yes i did.
      • retiredcaps
        • Apr 2010
        • 9271
        Yes i did.
        Sounds like the logic card. You could take the LCD apart and look for bad caps on the logic card. If you take it apart, post clear focused pictures of all your boards with a top down view (both sides).
        See attachment instructions.
        https://www.badcaps.net/forum/showthread.php?t=1868
        • tama4tama
          • Nov 2006
          • 56
          Here are the pictures of the board.
          • vegs
            • Mar 2019
            • 4
            • Turkey
            I have definitely same issue on same monitor. Did you fix the issue....
            • vegs
              • Mar 2019
              • 4
              • Turkey
              Ten years later I found same problem.
                09-07-2024, 05:50 AM
              • soopacrucial
                by soopacrucial
                Hi folks,
                10-29-2024, 02:40 PM
              • Ellos
                Samsung s21 sim recognized but no signal
                by Ellos
                I'm just starting out with smartphone repairs and picked up a Samsung S21 to work on. Everything functions perfectly except there's absolutely no cellular signal. The SIM card is recognized, WiFi works fine, but zero network signal.
                I've tested my SIM in another phone and it works perfectly with good signal, so it's definitely the phone.
                From what I've read online, this issue is usually caused by the network chip needing to be desoldered and reballed since one of the solder balls might be cracked.
                I think I've located the SOC that...
                06-27-2025, 01:31 AM
                09-06-2024, 11:40 PM
