Nichicon Replacement Cap (1980)
  • arrudi
    • Jun 2010
    • 8
    Hallo,
    I'am looking for replacement caps for an Onkyo A-15 amplifier build in 1980.
    Nichicon 0.47uF/50V. (M), 85°C, H8042
    Nichicon 1uF/50V, (M), 85C, H8042
    The caps have a yellow sleeve with black markings.
    The partslist list them as 1uF, 50V, LL or 0.47uF, 50V, LL.
    What makes me curious, is the LL and the yellow sleeve!
    I think, after 30 years of operation, replacing the caps, is not a bad idea.
    arudi
  • linuxguru
    • Apr 2005
    • 1564
    Re: Nichicon Replacement Cap (1980)
    I'm not familiar with the Nichicon LL series, if that's actually the series identifier. However, several of the Nichicon Muse series should be better replacements for those caps. Any of FG, KG, KZ and SW will work if they're polarized electrolytic, and ES should work if it's a non-polar electrolytic.
    1 uF and 0.47 uF are also available in Rubycon Black Gate PK from Parts Connexion. However, all Black Gates have a long burn-in period (100 to 1000 hours). In comparison, the equivalent Nichicon Muse SW has little or no burn-in period and sounds great immediately on installation.
    • arrudi
      • Jun 2010
      • 8
      Thank You for the fast reply.
      The LL is not a marking on the cap. Onkyo made a remark in the drawing and partslist to indicate, that these are spezial types. May be, they meant Low Leakage, as they are used at the input of OP-Amps.
      They did not use bipolar caps. Instead they put 2 caps in series, with the +contakt connected together.
      • Triodethom
        • 3
        bi polar are polar caps with the negs connected in one package rather than two . so Yes you have a non polar set up .
        • DaveHarry
          Seeking replacement for EOL Nichicon PLV1J220MCL1TD. Found APAQ and ELITE (CHINSAN)
          by DaveHarry
          Hi group,
          I am looking for a replacement for Nichicon PLV1J220MCL1TD (22uF, 63V, Conductive Poymer Aluminum Solid Electrolytic, 8x9 but we can go up to 8x11).
          While searching, I found some APAQ and ELITE replacements that would fit on our products (APAQ ARHA series and ELITE UGT and UPD series).
          How good are these brand/series and what other alternative would you recommend? I've searched the big name already and didn't find an equivalent.
          Thanks!
          05-27-2024, 08:08 AM
        • Hitto
          Fake Nichicon capacitors with almost-perfect sleeve?
          by Hitto
          Fake Nichicon capacitors with an almost-perfect sleeve?
          Same font, perfect logo, same size of the sleeve. The air vent looks okay. The diameter of the capacitors is correct per datasheet.
          It truly looks like the real thing.
          I doubt that you would distinguish it from a genuine one.. if it wasn't for the bung.
          Shall we be afraid, at this point, that even the bung can be replicated?...
          01-09-2021, 03:07 PM
        • reformatt
          by reformatt
          07-31-2025, 08:37 PM
        • BigTroll
          Nichicon PC(M) replacement
          by BigTroll
          Hello, Iam working on my dads EEC-IV computer from his 94 Lightning Pickup, it has bad nichicon PC(M) 2x47uf 16v and 1 10uf 63v what would be a decent replacement? I noticed Panasonic makes the General purpose NHG series any they are rated to 105c whould those be okay?
          also on the bottom left of the board capacitor I see I guess a diode or something, it has no markings and had electrolite under it which i cleaned, did that cap possibly short it out?...
          02-21-2021, 11:23 PM
        • the_rem
          Unknown transformer : how to find a good replacement part ?
          by the_rem
          Hello guys,
          I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
          I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
          04-23-2025, 01:48 AM
