What 'class' is this Hill Audio DX3000 Amplifier?
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1825
    • Spain
    Hi guys, this is general query really
    So I have a Hill DX3000 3KW audio amplifier here.
    It has a topology/design like a class A/B but all the banks of output transistors (10 transistors in each 'side' of the channel) are NPN.
    I was wondering what class this is. It doesn't fit the description of class A.
    It also doesn't match class A/B or B amplifiers as all the examples I see have a complimentary output stage desigs (NPN/PNP) and clearly is not G, H or D
    I looked for 'class A push pull' but that didn't tell me anything either
    Here is the schematic. So what is it?
    OOPS WRONG PIC - On moment
    thanks
    rich
    Last edited by dicky96; 05-04-2022, 04:22 AM. Reason: WRONG PIC LOL!!!! one minute...
    Follow me on YouTube
    Learn Electronics Repair
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1825
    • Spain
    Re: What 'class' is this Hill Audio DX3000 Amplifier?
    Try this pic
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8700
      Without looking at the schematic, likely Class AB.
      AB can also be all NPN or all PNP power transistors.
      Now after looking at the schematic, it indeed has a quite unusual design, but seems to fit just as well - still has all the characteristics of an AB design.
      • dicky96
        Sun Seeker
        • Mar 2017
        • 1825
        • Spain
        Thanks eccerr0r
        • Erico1
          • May 2022
          • 6
          @eccerOr
          The manual you provided describes it on page 5 as a "Super A" sliding bias configuration. See the first paragraph in the Operation section.
          Last edited by Erico1; 05-16-2022, 09:17 AM. Reason: added the page number to the reference source.
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8700
            The main characteristic of class B is evident in the design however - since only half of the transistors are on during a specific half of the waveform. Yes this design leaks like a class A but not as much as so due to the half waveform design, so it's tough to classify these.
            I don't see any advantage of this over a traditional AB design, just costs more with ugly transformer coupling...
            • Erico1
              • May 2022
              • 6
              I read an article that described it as an A+B type. The design is derived from Technics.
              • dicky96
                Does anyone have a schematic for Samson TXM16 Powered Mixer?
                by dicky96
                Hi guys
                Does anyone have a schematic for this? The fault is both protect lights on. I fixed one problem already that was causing the negative rail to both amplifier channels to go to -90V with +45V on the positive rail (It's a class G design)
                I now have 45V on both rails +/- but one of the amplifier channels has about 20V DC on all the emitter resistors and it all reads weird because the base of the NPN output transistors is about 8V so they are reverse biased, yet the base of the PNP output transistors reads about 19.3V, so 0.7V less than the emitters so those appear be forward...
                11-21-2022, 11:43 AM
              • MrCommunistGen
                Polk Audio RTi100 Plate Amplifier won't power on and intermittently honks and buzzes
                by MrCommunistGen
                My childhood best friend was killed about 9 years ago. His parents are finally letting go of his things, and they offered me his Polk RTi100 tower speakers. The Polk RTi100 towers are one of a handful of designs from the early 2000s that is a full range 3-way tower with a built-in self-powered subwoofer. This is accomplished with a plate amp integrated into the speaker input panel.
                I think they used them for a while, but they've been sitting for at least a few years now. After about 40 hours of driving to their house and back (both they and I have moved in the last 9 years) I got...
                07-12-2021, 05:11 PM
              • jinu_j
                How to test Subwoofer Amplifier with only a multimeter
                by jinu_j
                Hi Folks
                Need some advice on how to test a subwoofer amplifier if i have access to only a multimeter.
                Problem
                I have a Boston Acoustics active Subwoofer (soundware S). Its rated output is 200W. But the output i am getting is very low i can barely hear/feel it even if put the gain at max. I replaced all the capacitors in the Subwoofer amplifier but still no change.
                Is there anyway to test this without getting an oscilloscope/Function generator to see if the fault is with amplifier, driver or the source??
                Any advice would be appreciated...
                08-29-2024, 02:05 AM
              • UserXP
                Mackie CR4 amplifier no sound
                by UserXP
                Hi, people.
                I've got an amplifier assembly from Mackie CR4 parts. It's just an amplifier, there was no speaker housing, so I used my set of CR4s to test it.
                Anyway, upon connecting everything and hooking the "new" amplifier to an audio source, the sound played clearly and strongly for the first ten seconds. I was happy it was working. Then the sound started to fade out during the playback until it was no more. After it had "dropped to zero", there were two very short intervals of sound playing at the normal volume, as if the amplifier was trying to...
                10-17-2020, 05:06 PM
              • Francesc V.
                Rotel RSX-1056 amplifier. Troubleshoot a noisy channel
                by Francesc V.
                Hi:
                I've realized that one of the channels of this amplifier has no proper sound.
                This is the signal at the speakers output.
                As long as the audio coming in to the amplifier board (blue) looks ok although with some noise due to the wire, I think that there's nothing to look at the preamp section.
                Now, I could start looking at components to see whether I find the guilty one.......but I would rather prefer to ask for advice. Here there is the amp. schema. Which points would you check with the oscilloscope to gather...
                07-15-2025, 01:33 AM
