Caps in vintage receivers
  • Maxxarcade
    • Jul 2006
    • 973
    I rebuild quite a few vintage receivers these days, but I'm not sure about the caps I use.
    Since I also repair tons of other equipment (mainly computers and TV's), I mostly stock caps such as UCC KY, KZE, KMG, Nichicon PW, HM, Panasonic FC and FM.
    I usually use FC for anything in the audio path, but have also used KY, KZE, and KMG.
    Is there really any harm in using PSU rated caps in audio circuits, or in old linear power circuits? I've used PW, KY, and LXZ in a couple Marantz power supplies with no issues.
    Reason I ask, is I heard somewhere that it's a bad idea to use low impedance caps in certain types of circuits. Is this true?
  • japlytic
    • Oct 2005
    • 2086
    Re: Caps in vintage receivers
    I do not think there would be any issues in using low impedance caps in certain types of circuits.
    In a CCFL driver application in the LT1184 datasheet, the electrolytic capacitor between the ROYER pin and ground needs to have an ESR no lower than 0.5 ohms to prevent damage to the internal LT1184F high side sense resistor.
    Situtations where you have to use an electrolytic of an ESR no lower than a certain value appear to be limited.
    • eryjus
      by eryjus
      05-10-2023, 11:21 AM
    • Paxman_Swede
      by Paxman_Swede
      Hello!
      01-14-2025, 09:51 AM
      by momaka
      03-15-2023, 10:17 PM
    • captain150
      by captain150
      03-16-2025, 07:34 PM
    • Foetuss
      Gigabyte GA-6OXT :: caps question
      by Foetuss
      Good evening
      I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
      Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
      But I was also suprised about the bigger boys, which are 330µF 25V.
      Could it be they used 25V caps because they were cheaper / available at that time?...
      02-11-2025, 12:22 PM
