Re: Dbx 286 repair
good job!
Dbx 286 repair
Re: Dbx 286 repair
Good morning
I close the discussion as resolved, I waited a month for them to arrive, the problem was THAT4305, I ordered them from the parent company as a free sample and they arrived only yesterday, after having replaced all the chips on the board in the end they were those. .. the only thing I do not know is if only one was defective or all three because I replaced them all from the rush. That corporation sent them to me as a free sample because they are really hard to find. Thank you all for your helpLeave a comment:
Re: Dbx 286 repair
Good morning
I give you updates, unfortunately with the improvised probe I could not understand much, on some ic I had both the input and the output, on some I had a distorted signal on others nothing, I decided then (given the low cost) to replace them all, at the moment I have arrived the 4580r and 074c I have replaced them and nothing has changed, the Lm339dg must arrive, the other two the that 4305 and lm3046m I could not find them in Italy, lm3046m is on ebay but it comes from china and I don't dare to imagine when they will arrive ... does anyone know if there is an equivalent? I couldn't find it and apparently it's out of production. As for that 4305 the only one to have it in order with arrival in June is mouser waiting for some news thanksLeave a comment:
Re: Dbx 286 repair
ok then I will do so, in input I will put an audio signal, in output an amplified speaker with the hold connected to the ground output of the jack and with the signal I will go to inspect the inputs and outputs of the ICs. Tell me if this could workLeave a comment:
Re: Dbx 286 repair
you need some sort of a probe, either visual like an oscilloscope or audible like high impedance audio probe of some sort.Leave a comment:
Re: Riparazione Dbx 286
the insert is ok, possible there is no other way than with the oscilloscope? what do you mean by something like that?I still think you should get or borrow an oscilloscope or something in order to see exactly what is going on inside.
BTW... on the block diagram there is a 6.5mm audio jack called insert on the back. Work and lube that jack a bit. If it isn't making any contact, nothing works on the compressor side either.Last edited by falcontech; 03-15-2021, 02:24 PM.Leave a comment:
Re: Dbx 286 repair
BTW... on the block diagram there is a 6.5mm audio jack called insert on the back. Work and lube that jack a bit. If it isn't making any contact, nothing works on the compressor side either.Last edited by CapLeaker; 03-15-2021, 10:46 AM.Leave a comment:
Re: Dbx 286 repair
Do the "4305" chips have any other markings? 4305 sounds more like a production code (week 43 of 2005). Feel free to cross-check with the schematics I linked on page 1 here.Leave a comment:
Re: Dbx 286 repair
below is the description of the ic on the board, i have had a look and there are several op amps, i can't find that 4305 i don't understand what it isthe pictures aren't clear enough to see what is printed on the IC's. Sorry. Download the schematic and the block diagram. You successfully eliminated the problem being at the input stage.
The problem is either the switches (not giving any audio to the compressor) or between the compressor stage and the clipper.
There aren't that many IC's on the board anyway... if you wanted to shotgun it...Attached Filesif you find these attachements useful please consider making a small donation to the site
Re: Dbx 286 repair
There aren't that many IC's on the board anyway... if you wanted to shotgun it...Leave a comment:
Re: Dbx 286 repair
the LEDs do not move, it will be a little difficult to find an oscilloscope, if they do not have a high cost I could decide to replace them all, maybe one at a time in order to identify the culprit, you could tell me from the photo which are the opamps thanksLeave a comment:
Re: Dbx 286 repair
so the problem isnt in the input stage. When you turn that bypass button to off and talk into the mic, are the 8 leds on the compressor moving? you may have to fiddle around with the two pots a bit.
I am thinking the problem is one of the op amps. Are you comfortable changing surface mount IC's? If yes, I guess you need to borrow an oscilloscope to figure out which IC is the culprit. Then you need to read the numbers of the IC's and find the spec sheet on the internet in order to get the pin out. Then test the inputs and outputs of each op amp and see where things go in, but nothings comes out.Last edited by CapLeaker; 03-14-2021, 04:47 PM.Leave a comment:
Re: Dbx 286 repair
with the processor in bypass mode, are you getting any audio out?Leave a comment:
by Flaku_34Introduction:
Hello everyone, this topic is more of a knowledge sharing and look inside type of post, but for someone working on this model of display it might be useful. Recently I bought Acer Nitro XV273 XB MIIPRZX with busted electronic, but screen was intact, price was incredibly low, so I took a gamble and bought the unit and try to fix it. As I dug inside, I found out that my motherboard was not responding, although all voltages seemed fine. I wasn't able to find any reliable information about this monitor on the web (only some pictures of motherboards from Ebay). By some research...13 Photos-
04-18-2024, 12:47 PM -
by learnmoreHello Community,
I'm attempting to repair the SMPS on a Levoit 600S air purifier. The transformer is likely open. It has six pins. 2 pairs on the primary side (one pair tested open) and 1pair of legs on the secondary side. Legs on the secondary side are spread wide apart (end-to-end). I've circled them in blue. Dimentons of the transformer are 22x23mm. Marking on the transformer are EE16 1.9mH-B. Fuse for the powerboard is fuse 250V 3.15A. I've been unable to find an exact match and I'm hoping for some help here to find a suitable replacment.
Peace
LM...11-04-2025, 09:35 AM -
This specification for the Acer Predator PT315-51-7815 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the PT315-51-7815 boardview and PT315-51-7815 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 11:44 AM
This specification for the Acer Predator PH317-51-7815+Helmet VR Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the PH317-51-7815+Helmet VR boardview and PH317-51-7815+Helmet VR schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...09-06-2024, 06:45 AM
This specification for the Acer Aspire A515-51G-7915 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A515-51G-7915 boardview and A515-51G-7915 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 06:00 AM
- Loading...
