Denon DCD920 CD Player Service Manual help
  • Nevillet
    • Sep 2019
    • 272
    • United Kingdom
    I'm trying to track down a service manual for a Denon DCD920 but am drawing a blank. Can anyone point me in the right direction?
    Many thanks.
    Neville
  • R_J
    • 9535
    Re: Denon DCD920 CD Player Service Manual help
    What do you actually need, as there is the schematic on the internet.
    • Nevillet
      • Sep 2019
      • 272
      • United Kingdom
      This CD had a non opening drawer which has now been lubricated and fixed.
      It spins up a CD but I have no audio output or track details on the display.
      I connected a scope to one of the test points which started it playing.
      So i'm wondering if one of the adjustment pots needs tweaking - but which one?
      • R_J
        • 9535
        No pots need to be adjusted, Did you find the schematic?
        It might be more help if you said WHICH test point you touched.
        • Nevillet
          • Sep 2019
          • 272
          • United Kingdom
          Just brought it back to the bench and I can't seem to repeat the phenomena.
          I'm pretty sure I touched the FEO pin on TP101.
          It doesn't want to play or read the TOC.
          The CD spins. No disk data is displayed. Occasional focusing? heard.
          • R_J
            • 9535
            Do you get any eye pattern on tp102-1 (HF)? I would check that the spindle motor is not sticking and spins freely. if it spins slow it might not read. You did clean the lens ?
            • Nevillet
              • Sep 2019
              • 272
              • United Kingdom
              Yes I've cleaned the lens.
              When it did play the speed seemed 'normal'
              Below is the trace from tp102-1 (HF)
              • R_J
                • 9535
                That waveform is not very good, that's why its not reading, Have you checked that the +&-5v and +&-10v are ok and clean.
                • Nevillet
                  • Sep 2019
                  • 272
                  • United Kingdom
                  I measured the +/- 5V at the regulators and they are both stable and on target.
                  I need to take a closer look for the +/- 10V rails. There were no obvious regs like the 5V ones.
                  It's a bit late here and my bed beckons. Back tomorrow.
                  • R_J
                    • 9535
                    The +/- 5 volt regulators are supplied by the +/- 10 volts, so check the input to the regulators, Since you have a scope, check the ripple as well. The +/- 10v supplies the spindle motor drive.
                    I assume you have the schematic.
