Philips CDR775 part help please
  • zen
    • 511
    Apologies for repeating thread , but incorrectly listed chip required on header & couldn't alter it .
    Just a heads up , in case anyone has same issue .Problem on this dual CD unit was with the recording deck . No functions apart from turntable motor spinning very fast .
    Correction , chip is SAA 7392HL
    Not sure if i'm posting in the correct place .
    Chip is from the servo board .
    3 sellers on E BAY have it , but suspect they are all part of same company , as listings look identical .
    Sent a message asking if part is Original genuine chip , but no reply as yet .
    Very reluctant to buy from sellers i'm not familiar with , as have many fake & faulty parts in the past .
    Can anyone help with a good source of this chip.
    Have already proved chip is the issue by swapping one out from a fully working unit.
    Thanks Zen
  • acedogblast
    by acedogblast
    11-02-2024, 05:13 PM
    Common SPI bios chip programming Questions and Answers
    by SMDFlea
    Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
    A: If you can`t read from it how do you expect to write to it ?.
    Q: Why is my bios chip unreadable ?.
    A: The programmer is faulty or has a worn or broken zif socket.
    The USB cable is frayed,connector pins worn or some other physical damage.
    Not enough amperage or voltage to power the programmer properly.
    Bad...
    09-02-2021, 04:40 PM
  • BMCappelletti
    Asus Chromebox CN62 - wrong chip put on BIOS reader
    by BMCappelletti
    Long story short:
    - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
    - gave the computer to his son a couple years later
    - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
    - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
    (seems like the story was not that short)
    He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
    01-08-2025, 07:27 PM
  • Troystain
    Help EZP2023+ updated chip database for w25q256jveq?
    by Troystain
    Hello, anyone here have updated ezp2023+ chip database in .dat file format.
    I need to add w25q256jveq chip but I do not know what data should I type.
    I'm using the ezp chip dabase editor posted from here https://www.badcaps.net/forum/troubl...ro-programmers
    The currenty unit model that I am trying to detect is HP elitebook 640 g9 which is currently locked on admin bios....
    11-25-2024, 12:53 AM
  • inck243
    Acer e15-e5-576g-5762 bricked. Bios chip won't interface in AsProgrammer.
    by inck243
    Thanks for any help. The board version is DAZAARMB6E0 REV: E. The bios chip is winbond 25Q64JVSIQ1736. W25Q64JV is not available in AsProgrammer -- only BV CV FV or FW_1.8c. The chip won't interface with asProgrammer and a CH341A. When I have this chip on the board, the laptop will not post but when I plug it in to power, the blue LED lights up, also the orange when the battery is connected. When I push the power on button, keyboard backlight turns on and the fan starts briefely then turns off. But I can't do anything to program this bios chip so I bought another one.
    The BIOS...
    07-25-2024, 09:17 AM
