Denon AVR-S900W receiver repair struggles
  • ajvpb
    • Apr 2019
    • 13
    I picked up a Denon AVR-S900W with no power. Eventually I found a shorted 5339 3.3v regulator chip/ic on the hdmi board. I replaced that and was able to power on the receiver but it behaved oddly. Some of the buttons on the front wouldn't work, the volume knob wouldn't work and it didn't output any hdmi signal. I thought I may have soldered the new chip on wrong so I took it off and did some searching around. Apologies for the lack of zoom to see things more clearly.
    Service manual, on the page in question:
    https://www.manualslib.com/manual/95...age=125#manual
    Screenshot of same page, with my problem area.
    The two ic's in the middle of the screenshot are the 5339 ones. If you can make it out, they both output 3.3v to a shared line with a resistor connecting the two. That resistor doesn't exist, but the pads do. With one ic installed, I'm getting the expected 3.3v on one pad, but I still get 1.1XX volts on the other pad that should only be connected to the other ic which has been removed. I expected to get 0v there.
    I tested the 6 pin ic's that each line feeds and they all test the same via a diode test - So I don't suspect one of allowing current to backflow.
    I am relatively new to this and this is the deepest I've gotten into a repair so far. I don't know if the short in the ic heated up some traces in the pcb and shorted them out. I'm also a bit up against my understanding of circuit design and how to make sense of what I'm seeing with my voltmeter or what I should be looking for at this point. Any hints or tips are greatly appreciated.
  • MICHAEL dsouza
    • May 2024
    • kuwait
    Hello, My name is Michael i am new on this forum, saw your thread on Denon AVR-s900w, wondering if you managed to fix it, i have Denon AVR-2312 which is dead, i have checked the voltages there is 5.2 volts coming from the SMPS to the HDMI board, i have seen 5v going to the input of all the DC to DC converter IC but there is no output, i have the schematic of the same, would appreciate if you could guide m on this.
    • Cornito
      Denon AVR-2700H audio stops while receiver still works
      by Cornito
      Hello team,
      I've got a new issue with a Denon Avr-2700H.
      After several minutes working, receiver stops playing sound with a poc eared in the speakers.
      Receiver still work and display video with error message on display.
      Seems to me that is the main output relay.
      I'm looking for the service manual that I can't find for the moment.
      Does somebody have it?
      Regards...
      08-03-2025, 06:10 AM
    • basskilla
      Denon PMA 350SE receiver missing part,need help for rewiring.
      by basskilla
      Hi Friends!
      I have a Denon PMA 350SE receiver,the remote controller-sensor pcb panel is missing from inside and without this it not even powering on by the main switch.
      So there are two connector left one 8 pin and one 3 pin.
      Would be Someone so kind and tell me which pin should connet to where,to make it work?
      I attached the service manual and pictures from the connectors.
      Thank You for the answer,and best wishes!...
      08-14-2023, 02:59 AM
    • CDNBrewer
      Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
      by CDNBrewer
      Hello Everyone,
      I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
      Symptoms:
      • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
      • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
      • I swapped the Left and Right surround
      08-05-2025, 09:29 PM
    • wolf1976
      wireless receiver for 6 speeds fan control with remote control
      by wolf1976
      hi i have a receiver that is destroyed from the overvoltage i guess
      my question is has three wires u v w for driving a motor fan i found an other receiver wireless from aliexpresss with the same propertiew but for dc motor
      the motor fan has not label
      i have an other receiver operational
      In your opinion can i measure the voltage at the output ?
      what do you suggest me with a simple instrument multimeter or using someone instrument more specific ?
      thanks in advance...
      07-23-2025, 03:12 PM
    • CdDvdFlash
      DSE GE6878 possible TV receiver dying remote not working well
      by CdDvdFlash
      For this Dick Smith TV GE6878 (Thompson) I replaced the broken remote with a universal it kinda works though if its more than a few meters away sometimes the buttons register and sometimes they wont so I bought another remote from another brand and it has the same problem, I've had an old TV in the past that the sensor died completely and I replaced it to fix it could this be a similar problem? I tried looking for a service manual, spare parts for a receiver and a parts list but I couldnt find any info. can someone please help me to find the info online for a service manual or where I can buy...
      07-03-2024, 03:55 AM
