Mackie CR4 amplifier no sound
  • petehall347
    replied
    Re: Mackie CR4 amplifier no sound
    you said no volts across R22 i would expect there should be .
  • UserXP
    replied
    put it back and try the new transistor ..be sure of transistor pin out
    I barely managed to put this R22 back because it was very unapproachable to access its holes and keep the resistor in place for sodering. It fell out too many times.
    I will attempt to desolder Q2 without damaging it, but it is so tiny i am afraid the soldering iron is going to melt it. If it turns out Q2 is not faulty, I will have no replacement. My local stores do not have the SMD type of these amplifier transistors in stock.
  • UserXP
    replied
    I see that one contact of this R22 is connected to Z2 coming from the positive rail. The other is in contact with the ground through a joint near Q1.
    On the working unit, when probes are placed on this resistor, it reads 9.9~10kOhm.
  • petehall347
    replied
  • UserXP
    replied
    will be c39 charging up .. swap meter leads
    Swapped, no reading now. It stays at ".OL" on display.
  • petehall347
    replied
    try swapping meter leads
  • UserXP
    replied
    now measure the board where the resistor came from
    The same, it starts from 4.2kOhm and then slowly increases to 5, 6, 7...
  • petehall347
    replied
  • UserXP
    replied
    Unsoldered R22 from the PCB and measured, now it reads 9.9~10kOhm.
  • UserXP
    replied
    R22 is the first of the two resistor above Q2:
    -R22-
    -R91-
    -Q2-
    On the other unit it reads 10kOhm like it's supposed to be.
  • UserXP
    replied
    Hello, people.
    Sorry for this delay, hopefully you are all OK and safe.
    OK, here's the update: Today I bought four 2N5551 transistors for testing purposes, but I couldn't find the SMD version, so I though these would do for testing as budm suggested. Now, he suggested an open pathway between Q2 and the ground... I did some more testing...
    Now, I did some more measurements prior to deciding to unsolder the SMD Q2. I again tested its forward voltages and they are the same like in the previous measurements, around 0.600 and seemes OK. However, I decided to check the components again. Now, here is some interested news... I tested all the through-hole resistors in this area and refered to the schematics. The unit was off during these measurements:
    R87=4.7kOhm
    R88=4.7kOhm
    R91=5.6kOhm
    Now, R22 is strange and I think it didn't behave like this before. Sometimes the multimeter displays 00.00kOhm, other times it starts at 4.2kOhm and will not stop, it continues to show the increasing number of kOhms. If I move the probes and touch again, it continues to count where it left off, as if something is "charging" the resistance. I also got a positive continuity result when touched this specific resistor with the probes a couple of times, but not always. This happens only with R22.
    When I turn on the unit, the voltage across that resistor is 000.0mV and the resistance test shows 0. According to the specs, R22 should be around 10kOhms. Can a resistor become faulty and work intermitently, or are these readings due to in-circuit measurements.
    Does this tell us anything, is it normal?
  • UserXP
    replied
    any updates ?
    Sorry, I had a crazy week. Due to a sudden increase in the number of new corona cases in my country, there have been changes and new measures at my work being put into effect, so the whole week was in rescheduling and re-organizing activities and work from home, so I didn't have much free time.
    I will post back in a couple of days for sure. Thank you so much for helping me with this and for having the patience.
  • petehall347
    replied
    any updates ?
    replied
    You can use the through hole Transistor so it will be easy to solder for testing, the 2N2222 or 2N3904 are very generic Transistors so should be easy to get, just remember that pin out of the through hole is not the same as the SMD.
  • UserXP
    replied
    Originally posted by budm
    Do you have any small through hole 3-leg NPN Transistor such as 2N2222, 2N3904 around?
    I doubt that, but there is an electronics store relatively near by my place, I can go purchase one tomorrow (it's almost midnght here now ). Should I go for the ones you listed above or buy the 2N5551 one?
    replied
  • UserXP
    replied
    The service guy sent me these pieces of the schematics, but i asked if it would be OK to provide full specs since this product is no longer produced. I am waiting for a reply. Maybe we'll finally get the CR4 schematics. Too bad I won't know how to interpret them, though.
  • UserXP
    replied
    OK.
    Make sure to unplug the AC from the unit when making diode test, resistance test just in case the power switch is not hard switch.
    OK, not a problem, I always unplug the unit from the mains socket when in off state.
    replied
    OK.
  • UserXP
    replied
    Sorry, I spotted the error and while I was editing my post you replied.
  • soeren
    A2442 - No sound over internal speakers and no video playback
    by soeren
    I am facing a strange issue, I don't have any sound over my internal MacBook speakers and also the video won't start. If I change to my head speaker or via HDMI (speaker on my external Display) the sound works over the head speaker or Display and also the video starts (ex. youtube).
    All happened after the battery ran out of power overall several days when I was on vacation.
    I tried to remove the battery and then reconnected the battery, and then the MacBook Pro 14 2021 won't accept any power from my power socket. Then I removed one speaker, connected again the battery...
    07-26-2024, 01:24 AM
  • eduaqa
    Amplifier - bad sound when loud sound on bass
    by eduaqa
    I'n trying to fix a M&S SYSTEM DMC-1which have following problem:
    I'm using FM station to do this fix, I works perfect if volume below around 8 or if bass is set to zero, the sound can go to 20 without problem, but if I set bass to maximum and try to go over 10 the sound comes distorted ... I saw a video on YouTube the person saying about the main capacitors on the power portion, but I disconnect the main transformer and inject direct to the capacitors PINs my bench power supply -23v 0v +23v, but still distorted so I think the problem is not the capacitor neither the transformer...
    08-06-2022, 11:28 AM
  • Francesc V.
    Tele-master AS-20 amplifier. No output sound, just noise
    by Francesc V.
    Hi:
    I bought this amplifier from the 70s to try to repair it. So far it has no output sound, just noise. You can volume it up and down.
    I've checked fuses and all are ok.
    I've continued with capacitors:
    • The main black one should have 4700uF, but it has lost half of its capacity during these years.
    • The ones that I've numbered have still a really low ESR and the full capacity after ¿40 years?
    The 4 transitors are perfect. Desoldered and tested individually.
    There are also components which I don't know exactly what they are....
    02-16-2023, 07:55 AM
  • osamageris
    Sound Amplifier PA1240A JPA_Amp_1240A_Protection_Diagram
    by osamageris
    PA1240A JPA_Amp_1240A_Protection_Diagram...
    Badcaps Electronics Repair Forum & Schematic Search
    01-10-2025, 05:34 AM
    HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500T Specification for Upgrade or Repair
    This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
    09-12-2024, 02:30 PM
