acdelco amfm cassette 2700
  • nickster2213
    • Feb 2016
    • 18
    • canada
    how to replace volume rheostat with acdelco 2700?The unit is for my 1980 Corvette, I like to keep car all stock original for car shows.
  • redwire
    • Dec 2010
    • 3906
    Re: acdelco amfm cassette 2700
    If the volume control is scratchy or noisy, first try spraying a cleaner+lube inside the wafer. Like Caig Deoxit D5. Don't use WD-40. Check for cracked solder connections to the circuit board. These are common car stereo volume control problems.
    Otherwise, the potentiometer is likely a custom part that AC Delco uses. That would mean pulling the control out, and doing microsurgury to fix it, or getting one from another 2700 radio which was used for many years in many GM's.
    If the unit powers up but is dead quiet, the volume control is probably not the problem.
    • karthur
      Vizio D65x-G4 Volume changes on its own
      by karthur
      On this Vizio D65x, the volume will change on its own. I don't mean like during commercials where the volume will increase. I mean its like the (+) volume button on the remote is pressed and the actual volume dialog is displayed on the screen going up. It will do this, then the volume may start going down. It might go all the way to "0"or it might stop at a different number, then start going back up. The whole time its doing this, the volume dialog is shown on the screen.
      It wont do it until it has been "ON" for 20 or 30 minutes, so it does seem to be heat related....
      06-05-2025, 08:13 AM
    • crackedprint
      Sony HCD-HX80R Amplifier Volume Control Problem
      by crackedprint
      I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
      I have tried a Cold Reset as per the service manual.
      I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
      I have looked all the way through the service manual and tried many online...
      01-21-2025, 12:18 PM
    • BigOof
      Marantz SR5007 popping on volume change and mute in Direct Mode
      by BigOof
      I bought a used Marantz SR5007 and it's giving me some issues that I can't seem to really place. It functions well in most settings, ARC mostly works, it has no issues driving my speakers in any of the digital input modes, but I'm having issues running analog inputs in direct or pure direct mode. For some reason in this mode there's distortion for every volume increment I give it, but once the volume is stable it has no issues. Muting creates a loud pop, switching to another source also causes a pop and so does turning off the amp in that mode. Again, no issue in the digital modes....
      12-12-2024, 06:15 AM
    • Storyteller12
      Samsung Soundbar Q900T Cuts Off if Volume above 30
      by Storyteller12
      I have this soundbar and when I turn it on it works until I turn the volume above 30.
      Then the display show “PROT” protection and shuts off.
      I can turn it right back on and it works until volume hits 30 again.
      There is a little static on the surround speakers so I unplugged them but still have same problem. I tried unplugging all speakers also and when volume goes above 30 it shuts off.
      I can turn the volume above 30 if nothing is playing but as soon as I play something it shuts off.
      It will play fine for hours with volume...
      03-21-2023, 12:31 PM
      HP EliteDesk 705 G4 EliteDesk 705 2700 Specification for Upgrade or Repair
      This specification for the HP EliteDesk 705 G4 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 705 G4 boardview and EliteDesk 705 G4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
      09-12-2024, 02:30 PM
