Pioneer SX-434 repair thread
  • amelbye
    • 46
    • Norway
    Hi, I'm trying to repair an SX-434 for a friend.
    As of now all the outputs are blown. Completely my fault. Long story short, they had to be replaced. Original parts were NLA, so I replaced the Sanyo B507D (PNP) and D313D (NPN) with 2N6042 (PNP) and 2N6045 (NPN), by matching up specs. I found parts recommended across the web but they were all expensive, so I decided to match them up myself.
    So I soldered them all in, and here's my first question:
    All the collectors are connected together at the heat sink. I can't recall if there were isolation pads or not (I had to set the project aside for a few months and just got back to it). I don't see myself throwing them out, but there aren't any. Should there be?
    I don't see them all joined together in the schematic, but I'm hoping someone here will be fimiliar with the type of design and able to tell.
    Service manual is easily available (schematics at the end):
    Here
    or here
  • R_J
    • Jun 2012
    • 9518
    Re: Pioneer SX-434 repair thread
    You are replacing regular transistors with darlingtons, that will not work
    Try MJE15033G and MJE15032G
    Well the collectors of the pnp's are connected to -24 volts and the npn's are connected to +24 volts, what do you think will happen if you connect them all together?
    Also the heatsink is likely at ground so Yes you need insulators
    And you need to check all the driver transistors AND all the resistors in that circut.
    Then use an incandescent lamp in series with the a/c line as protection when troubleshooting.
    • amelbye
      • 46
      • Norway
      Thanks R_J!
      I didn't realize darlingtons wouldn't work as replacements (because I don't know what darlingtons are), I thought I was being clever
      And regarding the heat-sink isolators, I didn't realize exactly what voltages would be present, but this is exactly what I was guessing.
      I'll look over all transistors and resistors in this part of the circuit.
      The reason I started troubleshooting to begin with was that one channel had no bias voltage. I'll do what you advised and post back if that issue remains.
      Thanks again!
      • amelbye
        • 46
        • Norway
        I put in the MJE15033G and MJE15032G and the amplifier works!
        Now, here's the procedure for aligning the power amplifier:
        I'm confused by this. point 3: does it mean that I should cut the jumper if my voltmeter gets a positive readout?
        same goes for point 4, cut the jumper for any amount of negative readout?
        I get -16mV on one channel, and -8mV on the other between pin 24/27 and ground.
        • R_J
          • Jun 2012
          • 9518
          Those voltages look close enough, I would leave the jumpers in place, they will likely change as the amp warms up.
          • amelbye
            • 46
            • Norway
            after warm-up voltages between point 27 and 24 and ground move to -20mV and -10mV.
            I guess these voltages are the center point of the amplifier and should be somewhere around 0 if the output gains are reasonably matched?
            In the amps I've done in the past I've adjusted center point by running the amp into clipping with a sine wave input, then adjusted for symmetrical clipping. I guess this is just a simplified way to deal with this?
            The bias voltage is 25mV on both channels. Should be more than 5mV it says, doesn't say anything about what to do if it's too high, so I guess I can leave that alone as well?
            This amplifier will not be seeing a lot of punishment, so a reduction in output is not a problem, as long as it doesn't affect reliability.
            • Bushcat
              Pioneer PL-X9 motor speed control wobble
              by Bushcat
              I'm starting to re-cap a Pioneer PL-X9 turntable, specifically the motor control board, because although everything tests out OK according to the service manual, the speed wavers slightly despite the quartz lock light remaining on. So, I've decided to re-cap that board since it's the cheapest next step...
              Pioneer's passive component naming convention is clear to me. For example, CSZA R22M 35 is tantalum, radial leads, 0.22uF, 20%, 35V.
              BUT there are two capacitors on the board which have actual Pioneer part numbers: PCL-042. I can tell they are 0.1uF, 16V but don't...
              05-24-2023, 03:36 AM
            • pixelcap
              Pioneer Kuro Pro 111FD 8 red blink error
              by pixelcap
              Pioneer Kuro Pro 111FD 8 blink red LED.
              I have been trying to solve the power-down 8-blink red LED problem with my Pioneer.
              So far I have replaced the power supply board, and the digital assembly board, I have reconnected the ribbons to all boards, ensuring the connections are good. Even though the problem is the 8 red light error and not the more common 8 blue light error code, I had Kcrownie,
              based in North Carolina replace the chips that cause the 8 blue LED problem (the main board and audio board) the plasma is still powering...
              10-06-2024, 11:26 PM
            • RatherLoopy
              Pioneer VSX-44 receiver HDMI dropouts
              by RatherLoopy
              I have an older Pioneer receiver (VSX-44) that's been dropping the HDMI output (black screen) for a few seconds every few minutes. Setup is HTPC -> Pioneer DVD HCMI in -> Pioneer HDMI out -> Samsung TV HDMI in, all with cheap HDMI cables that have never caused trouble before..
              I initially found a lot of play in the receiver's HDMI inputs and output so I kind of squeezed them back into shape and they're making a tighter connection, but the problem persists.
              And also, often, the HDMI will drop out in exactly the same way (black screen) just as my central air...
              05-26-2023, 03:54 PM
            • Evets
              Pioneer sg530
              by Evets
              This forum has been so useful to me and I thank all the people who have helped me in the past.
              I'm now in need of some more assistance, I have purchased a Pioneer sg530 graphic equaliser to add to my Pioneer X-G7 hifi system. This equaliser was a factory option on this system but as this was purchased second hand I didn't get a user manual. Searching the internet has been fruitless, can anyone help with a schematic of how this should be wired into the system or possible a copy of the user manual.
              07-30-2024, 07:18 AM
            • Servicem4
              Pioneer lx 701 hdmi issues
              by Servicem4
              My receiver pioneer LX 701 doesn't work anymore correctly The history:
              6 month ago hdmi picture output didnt work anymore but music input through hdmi still worked.
              Since some weeks even this doesn't work. Right Before this occured i heard a plopping noise from the receiver one evening.
              The rest of the receiver works, I used spdif for sound input.
              I now opened the receiver and hoped to find a blown fuse but all look good.
              Any tips how to progress? Between 2 PCB there is something which looks like a blown cap....
              Image 20250527-204839 hosted in ImgBB
              05-27-2025, 01:13 PM
