Pioneer VSX-1020 won't start /relay click /
  • coojoe_213
    • Nov 2015
    • 105
    • bulgaria
    Hi. Yesterday receiver ''stuck/freeze'' on ''POWER ON''. Today no display, no blink, only main relay click. All compination enter+power button etc.... doesmt work.
    Amp section is perfect.
    On IC581 all correct ( i have input 5V/OUTPUT 3.3V)
    On D582 /cathode/ i have 2.7v
    C333/C506/C552/C606 are good, correct voltages.
    I don't have osciloscope to check crystals on processor. May be receiver won't boot firmware...
    Can you tell me how continou.
    Service manual is too big (32mb) to upload here, here is a link
  • RatherLoopy
    Pioneer VSX-44 receiver HDMI dropouts
    by RatherLoopy
    I have an older Pioneer receiver (VSX-44) that's been dropping the HDMI output (black screen) for a few seconds every few minutes. Setup is HTPC -> Pioneer DVD HCMI in -> Pioneer HDMI out -> Samsung TV HDMI in, all with cheap HDMI cables that have never caused trouble before..
    I initially found a lot of play in the receiver's HDMI inputs and output so I kind of squeezed them back into shape and they're making a tighter connection, but the problem persists.
    And also, often, the HDMI will drop out in exactly the same way (black screen) just as my central air...
    05-26-2023, 03:54 PM
  • pulper111
    Pioneer VSX-1123 Receiver - weird voltage problem
    by pulper111
    Hello. My receiver "seems" to be working fine. It functions as it should. the receiver is the Pioneer vsx-1123. However, while doing some work in the house, I noticed that my HDMI cable from the receiver was registering as "hot" using my fluke non-contact voltage tester.
    I've done some troubleshooting to try to narrow down the problem, and all wires (speaker/hdmi/subwoofer) coming from the receiver, whether it's powered on or stand-by, register as "hot". none of my other receivers are experiencing this issue, so it doesn't seem to be an issue with...
    09-02-2020, 11:12 AM
  • GraphicMan
    Pioneer amplifier A-205 Relay not clicking after a mistake i made
    by GraphicMan
    Hello guys
    Because the unit is old (but only occasionally used) the loudness button causes some noise due to bad contact,
    sprays did not work, so i decided to solder the pins that it connects on the pcb at the on (loudness on) position
    i did that and it worked fine, i know from the bottom of my heart that the switch connects 2 pins and also d/c other 2 pins
    on every position it have (6 pin switch), so i was curious what would happen if i clicked the switch off while the pins are soldered at on (so basiclly on and off at the same time), when i did so the sound is gone, nothing...
    05-05-2024, 06:20 AM
    Acer Aspire A315-34-C552 Notebook 3 Specification for Upgrade or Repair
    This specification for the Acer Aspire A315-34-C552 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A315-34-C552 boardview and A315-34-C552 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
    09-07-2024, 03:40 AM
  • CoinCoin88
    Garage door RX unit (Cardin S38C) does not short relay to send opening signal
    by CoinCoin88
    I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
    Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
    09-15-2025, 03:36 AM
