JBL ONBEAT VENUE LT does not work
  • Piotr07
    • Oct 2015
    • 17
    • Poland
    There must be a problem in the mainboard. Main voltage 18V from PSU is changed to 5V and 3,3V on mainboard but the microcontroller STM32F105 does not start , all LED's are off after power on.
    Do you know about some microprocessor reset function through keyboard for JBL ONBEAT VENUE LT ?
    Or is it some software problem of memory loss ?
  • ystycy
    • Mar 2014
    • Romania
    Re: JBL ONBEAT VENUE LT does not work
    did you found any solution ?
    • hollox123
      ASUS ROG Strix G713QR - Keyboard, backlight and side LEDs don't work
      by hollox123
      Hello, I have an "ASUS ROG Strix G713QR" laptop, and for approx. 3 months I have the following problems:
      1. Laptop keyboard doesn't work
      2. The backlight on the laptop keyboard doesn't work
      3. The x2 side LEDs (red) on the laptop don't work
      The power button works, the touchpad works, and all the USB, HDMI, Ethernet, etc. ports work.
      I already tried to reinstall all the drivers and reinstall Windows. So I don't know what to try anymore that is software-related.
      But I am strongly aiming that it is somehow a BIOS-related problem,...
      05-11-2025, 08:05 AM
    • orcic
      MASTER TL240 and new mainboard LW36BKC01
      by orcic
      I have an old MASTER TL-240 LED TV. Since it stopped working and it had a DVB-T receiver that is being dismissed in Italy, I've decided to replace the mainboard with a DVB-T2 one.
      The original problem was that when switching on the TV, the power LED was transitioning from red to steady blue, without showing video or audio.
      After checking some voltages on the power supply board (HKL-240101-B Rev. 1.4, HKL from now on) someone suggested me to replace the mainboard.
      Now I have some doubts about how to connect the new mainboard to the old power supply.
      First of...
      05-12-2023, 08:10 AM
    • stylishconsultant
      un60j620dafxza - Samsung No Display Problem
      by stylishconsultant
      Hi All,
      Need help.
      I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
      So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
      problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
      might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
      09-04-2024, 03:26 AM
    • stavi
      NVR mainboard USB not work, short?
      by stavi
      I would like to ask for help to repair an NVR motherboard.
      The NVR itself is working fine, but the USB devices are not. No mouse, keyboard, flashdrive, etc. When plugged in, the mouse does not light up either.
      I have checked the usb pin, I get a very strange voltage:
      I didn't feel much warming (with my hand).
      Where do I start troubleshooting? Any ideas?
      Unfortunately I am a beginner in troubleshooting, but I can solder
      Many Thanks...
      12-20-2022, 09:02 AM
    • Malva
      Problem LG 49UB850V (Mainboard: EAX65684604 / EBT62954607)
      by Malva
      I'm trying to repair my LG 49UB850V TV (WebOS 1.0, UHD model from 2014).
      Mainboard model: EAX65684604
      PCB marking: EBT62954607
      SPI chip: Winbond W25X20CLNIG Problem description:
      Originally, the TV would turn on (backlight and LED OK if I force them on), but it shut down as soon as any input was received from the IR sensor or remote. The backlight and power board were working fine.
      After testing and verifying the voltages (DRY ON, PWR ON, 12V/24V rails), I suspected a corrupted SPI firmware. What I tried so far:
      • I bought another
      06-25-2025, 02:07 PM
