TOA 900 series ii Amplifier P-912MK2
  • R_J
    replied
    Re: TOA 900 series ii Amplifier P-912MK2
    R121 and R122 are basically in parrallel, one end is connected together and the other ends are connected via R123 and R124 so R121 or R122 will read one half or 500 ohms (0.493k)
    R127 and 128 will each read 1K because R126 is open.
  • Bterrier
    replied
    Originally posted by R_J
    So q117 checked ok, and could be good but I would not chance it. the other transistors should check this way also.
    Q117 and Q116 are PNP so Black probe on base you should read .5xx when checking to c then E
    Q115 and Q114 are NPN so RED probe on base you should read .5xx when checking c then E
    Measuring between E and C should always be OL in diode test
    Now because these transistors are shorted, they could have supplied the 45 volts back to the driver transistors, this may or may not have damaged them, they should at least be checked with the meter.
    Ok, so I took your advice and tested Q110, q111, q112, q113, r117, r121, r122, r127, r128, r130.
    q113 tested good. q110, q111, and q112 are NG. All resistors tested good except I am unsure about R121 and R122. The schematic shows a value of 1k. I am getting a reading of 0.493K.
    I will definitely replace q110-q117 as well as r125/r126. Unsure about r121 and r122.
  • R_J
    replied
  • Bterrier
    replied
    Now I'm confused. in post #33 you said QUOTE=Bterrier;823117]
    Q117 (black probe to base'
    Base to collector = 0.536v
    Base to emitter = 0.538v
    Probes reversed = OL
    [/QUOTE]
    I apologize if I have confused you. There has been a learning curve here for me. Prior to post #33, I was not accurately testing the transistors. The numbers in post 33 are accurate and current
  • R_J
    replied
    Now I'm confused. in post #33 you said :
    Q117 (black probe to base’
    Now you say Q117 reads OL ?
    Q114,115,116 are checking shorted, correct? If you measure across the transistor leads and it measures the same as if the probes are placed together, the transistor is shorted.
    You would need to replace all 4 outout transistors. You can use 2 axial resistors but they do sell the ones I posted also which are ment for this.
    I have no idea what caused the issue, where did the amp come from? It could have been the amp that self destructed or something that was connected to the output that should'nt have been connected.
    I would use a variac to slowly increase the ac to the amp to test it aftre the parts are replaced, you can use a incandesent lamp (60-100w) in series with the ac line to limit the current and help prevent the amp from blowing up if there is a problem.
  • Bterrier
    replied
    I might not understand the "0v" If you short the probes together on your meter is it the same "0v"?
    It looks like the only only transistor that might have checked ok is Q117
    With those output transistors disconnected, also check Q110,111,112 & 113, and R117, R121,R122, R127, R128, R130. They may have been damaged.
    R126 is open, they usually open due to a shorted output transistor like Q116, If it shorts it applies the full 45 volts across that .22 ohm resistor, it will open almost instantly.
    There should have been a high voltage measured of either + or - 45 volts on L101 but due to the open ground trace I suspect thats why it read 0 volts earlier.
    Yes I just checked on my meter and if I touch the probes together in diode mode, it reads 0V. Strange because it reads OL on q117.
    With these readings, do q114, q115, and q116 need to be replaced? I will recheck all of the smaller transistors and resistors you mentioned.
    As for R125/R126, I contacted TOA and they have discountinued that replacement part. If I cannot locate an exact replacement, can I simply utilize 2 axial 0.22 5w resistors?
    Also is there anything that would cause the transistors (q114-q117) to short? I wouldnt want to have them short again once I replace them and power .
  • R_J
    replied
  • Bterrier
    replied
    Check the reading with Q117, it should be the same (PNP) transistor. The readings you gave were:
    Q116 - Collector to Emitter = 0V " "
    Base to Emitter = 0V " "
    Base to Collector = 0V " "
    Q117 - Collector to Emitter = 0.144V " "
    Base to Emitter = 0.144 " "
    Base to Collector = .005 "
    They don't look right at all, Q117 seems to be shorted according to your reading.
    Is that with the black probe to the base and the red to the C & E ?
    then did you reverse the probes and do the test again? ?
    Q114 & Q115 (NPN) should give similar reading BUT with the probes reversed
    Have a look at this video https://www.youtube.com/watch?v=IY5UEbNB_fo
    Apparently I was testing these transistors incorrectly. I removed Q117 and Q116 from the board. Q114 and Q115 are still installed. Here are my results:
    Q114 (red probe to base)
    Base to collector =0v
    Base to emitter =0v
    Probes reversed =0v
    Q115 (red probe to base)
    Base to collector =0.005v
    Base to emitter =0.005v
    Probes reversed =0.005v
    Q116 (black probe to base)
    Base to collector = 0v
    Base to emitter =0v
    Probes reversed =0v
    How do these transistors look now with these results? Retested R126 with q116 and q117 removed : still a reading of 1.96k
  • R_J
    replied
  • Bterrier
    replied
    I also re-measured resistance across R126 with the tranistor Q116 removed and I am getting 1.96K
  • Bterrier
    replied
    I did remove Q116 from the board and I am still getting the same readings as before. Is there another way to test this transistor? Is this a different type of transistor?
    I am going to replace the emitter resistor, but I also want to ensure the these large transistors aren't the root cause.
  • Bterrier
    replied
    On the transistors you mesured Q114-Q117 you only have the one reading, did you reverse the probes and do the check? If they are are not checking properly, unsolder the E & B from the board and check them,
    It might be hard to find that exact type of emitter resistor, they make others or you can just replace them individually.
    Yes, I did reverse the probes. I got the same reading both ways. I will unsolder and test.
  • R_J
    replied
  • Bterrier
    replied
    How was your meter set when you checked the transistors, and did you have power on or off?
    Does your meter have DIODE test? You need to check the transistors that way, with power OFF You are not measuring voltages!
    in diode test if the junction is good it should read .6 or .7 one way and OL the other. It is like checking two diodes, base to collector is one, base to emmiter is another, then lastly check emmiter to collector, this should be OL or open.
    R126 looks like it IS open, that usually indicates Q116 could be shorted.
    Yes my meter was set to Diode mode, which is why I am confused. When I test the small transistors, I get results of around 0.5 and OL when reversed. I am not sure what to make of the results from Q114-Q117.
    Do you know where I can find a replacement for R126? I checked mouser but cant seem to find what I need
  • R_J
    replied
  • Bterrier
    replied
    Check the transistors using diode test on your meter, with power off check for a short between collector and emitter, ther should not be low resistance, then check from base to emitter, then base to collector, depending on the probe polarity and the transistor you should read about .6xx one way and open or high resistance the other way.
    make sure your repair is'nt causing a short.
    I assume you have installed the board back in the unit, make sure you have the grey insulators between the output transistors and the heatsink.
    The schematic seems to have mixed up pins 2 & 3 of CN106, although they are both ground, pin 3 is the ground that goes to the relay and then to other parts of the circuit.
    Although those traces looked bad, slightly melted, were the actually open? or just looked bad.
    I just tested the transistors. Here are my results, maybe you can assist me with analysis.
    Q114 - Collector to Emitter = 0V regardless of polarity
    Q115 - Collector to Emitter = 0V " "
    Base to Emitter = 0.005 " "
    Base to Collector = 0.005 " "
    Base to Collector = .005 " "
    I also went back to test the emitter resistors again because the fuse initially popped when I was checking voltage on these.
    R123=0-0.1
    R124= 0-0.1
    R125= 0.01
    R126=239.4
    I am thinking that the 2nd emitter resistor is bad? Or can something else cause this?
    The traces are ugly. One of them was just ugly, but the other was open so I repaired that one. I only repaired the open part for now until I can get the board operating properly. The repair is not shorting anything.
    I am going to reinstall the board now
  • R_J
    replied
  • Bterrier
    replied
    I did mke the repair to the trace and now have continuity. I think that may have fixed the protect mode issue, but I cant be positive because the fuse keeps blowing. It is F101 250v 6amp.
    It is strange because it didnt pop at all until last night. Any advice as to what may be happening?
    How do I test the four main transistors? Q115, q116, q117, q118?
  • R_J
    replied
    Where the bad trace is, just solder a small piece of wire between the plug connection and the relay contact then to the other spot I marked. Also resolder the connections on that relay, and any others that look bad.
    Those traces were getting hot due to the current running through them, it may be that the traces where a bit under sized,
    If the trace was actually open, then it could cause the fuse to blow as it is ground for part of the curcuit. Repair it and hopefully the amp is ok
  • Bterrier
    replied
    I have disconnected and removed the pcb a few times thus far, the most recent being after the fuse popped.
    I did notice something upon removing the pcb this time. It appears that par of the trace is damaged. Appears to be the section connecting Pin 3 on cn106 to ry101.
    At first I thought this may have occurred after the fuse issue, but looking back at a previous photo from earlier in the night, the issue was already there. Please see attached photos.
    The photo with red circles is prior to the fuse/short issue. The other is after the fuse popped, but also after I touched it.
    Could this be the sole issue? How can I repair this?
  • Kjell
    Samsung Series 9 - BIOS issue
    by Kjell
    After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
    Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
    08-01-2025, 09:15 AM
    ASUS Pro Series D320SF-I564000134 Pro Series i5-6400 Specification for Upgrade or Repair
    This specification for the ASUS Pro Series D320SF-I564000134 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320SF-I564000134 boardview and Pro Series D320SF-I564000134 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
    09-12-2024, 03:28 PM
    ASUS Pro Series D320MT-TR362D Pro Series i3-6100 Specification for Upgrade or Repair
    This specification for the ASUS Pro Series D320MT-TR362D can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320MT-TR362D boardview and Pro Series D320MT-TR362D schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
    ASUS Pro Series D310MT-0G32500650 Pro Series G3250 Specification for Upgrade or Repair
    This specification for the ASUS Pro Series D310MT-0G32500650 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D310MT-0G32500650 boardview and Pro Series D310MT-0G32500650 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
    ASUS Pro Series D320MT-I564001774 Pro Series i5-6400 Specification for Upgrade or Repair
    This specification for the ASUS Pro Series D320MT-I564001774 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320MT-I564001774 boardview and Pro Series D320MT-I564001774 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
