Bosch auto cd 7649168391
  • mehatronic
    • Oct 2016
    • 11
    • Croatia
    greeting,
    please help with help:
    I have a car cd player in Reno Bosch, which is not an avatar. :glazba, muzika:
    I removed the chip TDA7566 out and wanted to scan it-singles channels.
    I plugged it into a 13V power, connected sound to a single channel and a speaker.
    I do not get any sound.
    I put together all the masses on pins 1-2-8-13-18-24.
    to test whether this chip must have I2c pin 22-25 clk data or that is not necessary
    Thank you
  • Agent24
    I see dead caps
    • Oct 2007
    • 4958
    • New Zealand
    Re: Bosch auto cd 7649168391
    You should upload your pictures directly to the forum, most people aren't going to bother downloading an archive.
    TDA7566 Datasheet shows block diagram on page 5. This shows mute switch controlled by I2C. Most likely you won't get anything from it because you didn't send unmute commands on I2C bus.
    So you will need a micro-controller etc to make this thing work.
    You are better off using a TDA7560 instead, which does not have/need I2C control. The mute and standby function is controlled with standard logic level inputs. Other than that it is effectively the same chip.
    -David VanHorn
    • mehatronic
      • Oct 2016
      • 11
      • Croatia
      Agent24:
      thank you
      regards
      • mehatronic
        • Oct 2016
        • 11
        • Croatia
        Agent24:
        does not mean anything about the chip's correctness test without I2c commands.
        it's OK - a new chip has been bought -Ebay - I'm waiting for it to come.
        thank you very much for the information
        regards
        • Agent24
          I see dead caps
          • Oct 2007
          • 4958
          • New Zealand
          I just realised, are you trying to fix the car radio?
          I thought you wanted to make your own amplifier from the chip inside.
          -David VanHorn
          • mehatronic
            • Oct 2016
            • 11
            • Croatia
            yes, repair:glazba, muzika:
            no sound or one channel.:violina:
            • Agent24
              I see dead caps
              • Oct 2007
              • 4958
              • New Zealand
              Maybe bad amplifier IC then, but if not, you can check two things then;
              1) Trace the signal - does the chip receive any audio input?
              2) Check for signal on output pin, it may be lost on its way to the speaker due to broken connection, open-circuit component etc.
              -David VanHorn
              • shouri
                Dell latitude e5490 auto restart
                by shouri
                Hi guys, can someone help me?
                I have an issue with laptop dell latitude e5490 that auto restart when arrive at certain point in loading windows.
                Board model is dm70 la-f401p rev:1.0 2017-09-20.
                At first, the issue is sometime ssd sata 2.5 not detected. i already try another cable, at certain point, it ok using old cable (i mean sata cable here).
                After a few days test, is seems ok.
                Days later, another issue come, that is auto restart when certain point in loading windows. i already test another ssd, another ram, another sata ribbon, still same....
                12-10-2024, 09:27 PM
              • Petr0x
                Bosch 12V and 18V chargers modification
                by Petr0x
                Hi, I would like to share with you small modification to your Bosch tool 12V and 18V chargers.
                You can use it for almost all Bosch chargers what I have seen, for example part numbers GAL 18V-20, GAL 18V-40, GAL 1880, GAL 18V-160, AL 1820, AL1115CV, AL1130CV.
                Bosch (today also other brands using the same system like Wurth, Fein) does not care if you destroy your batteries, because they can sell you new ones. So the marketing is telling you only about speed of the charging, so you will not wait for your batteries to charge too long. Me as a customer want the tools and batteries...
                05-24-2024, 01:00 PM
              • CapLeaker
                Bosch Nexxt 500 dryer blinking start button - no start fix
                by CapLeaker
                My Bosch NEXXT 500 dryer quit today, press start nothing happens and the start button just keeps blinking. Not cool. Reset the dryer, same thing.
                Even so the buttons feel good, my problem was the start button smd tactile switch on the PCB. Cleaned the switch with alcohol followed with Deoxit and the sucker runs like a champ again.
                I like these easy evening fixes!
                12-07-2023, 04:38 PM
                DELL Precision 5820 Precision 5000 W-2225 Specification for Upgrade or Repair
                This specification for the DELL Precision 5820 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Precision 5820 boardview and Precision 5820 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                09-12-2024, 03:44 PM
                FUJITSU CELSIUS M7010 CELSIUS M W-2225 Specification for Upgrade or Repair
                This specification for the FUJITSU CELSIUS M7010 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the CELSIUS M7010 boardview and CELSIUS M7010 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for FUJITSU...
