Pioneer VSX-827
  • Stanem
    • Sep 2016
    • 22
    • sweden
    Pioneer VSX-827
    Hi all!
    Having problem with my receiver, most things are working except that I get no HDMI-signal out... Have been searching on the net but found nothing, not even a schematic for it. I had a Onkyo before that had bad capacitors, easy fix and now I hoped for something similar but haven´t found anything about it. The HDMI-board is named ANP7814-4. Anyone have any idea about what to do?
  • Bushcat
    Pioneer PL-X9 motor speed control wobble
    by Bushcat
    I'm starting to re-cap a Pioneer PL-X9 turntable, specifically the motor control board, because although everything tests out OK according to the service manual, the speed wavers slightly despite the quartz lock light remaining on. So, I've decided to re-cap that board since it's the cheapest next step...
    Pioneer's passive component naming convention is clear to me. For example, CSZA R22M 35 is tantalum, radial leads, 0.22uF, 20%, 35V.
    BUT there are two capacitors on the board which have actual Pioneer part numbers: PCL-042. I can tell they are 0.1uF, 16V but don't...
    05-24-2023, 03:36 AM
  • MotherTeresa
    Onkyo TX-NR5007 (NR3007 NR1007) NAND DUMP for DZKB4 DSP
    by MotherTeresa
    Hi.
    I'm looking for a DSP NAND DUMP for the Onkyo TX-NR5007 that works with the DZKB4 chip. Can anyone help?
    Regards.
    09-20-2025, 12:09 PM
  • EduCabral
    [Help Needed] Yatour YT-M06 (Pioneer 1) – Firmware or Schematic Request
    by EduCabral
    I'm currently working on reviving a Yatour YT-M06 CD Changer Emulator module for use with a Pioneer 1 interface (specifically with a DEH-P5950IB head unit).
    While the unit is recognized as a CD changer, none of the USB, SD, or AUX features respond, which leads me to believe the firmware may be corrupted or incompatible.
    🔧 Details:
    • Model: YT-M06
    • Interface: Pioneer 1
    • MCU: Fujitsu MB89F202
    • Goal: Find a valid .bin firmware file or memory dump from a working unit
    I'm happy to attempt flashing, analyzing memory dumps, or doing hardware-level...
    07-15-2025, 12:26 AM
  • FrancescoV
    Onkyo HT-R390 no sound output, video output ok
    by FrancescoV
    Good morning everyone,
    I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
    The firmware reported is the following:
    M:1.00/11107BLP
    D:?.??/????????
    O:1.00/11107AL
    The DSP firmware given the question marks seems corrupt.
    On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
    05-11-2025, 02:59 AM
  • CDNBrewer
    Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
    by CDNBrewer
    Hello Everyone,
    I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
    Symptoms:
    • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
    • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
    • I swapped the Left and Right surround
    08-05-2025, 09:29 PM
