Sony CMT-L1 (HCD-L1) repair, audio mutes, cyclic, intermitently
  • Chungalin
    • Jul 2014
    • 423
    • Spain
    This compact CD-Tuner set had a very intermitent failure. First time I returned it to the customer without being able to verify the symptom. More than one year later it comes back with same problem, according to the customer: CD skips. Again, it doesn't do this initially, but after some hours working it starts making a cyclic mute, with a period of 2 seconds. Some audio is heard for a fraction of a second, then mute, repeating this forever. No problem through headphones. Not sensitive to knocks / vibration. Same from all sources (CD, Tuner, Aux in). Looks like a S-Master amp problem instead of a CD issue.
    Once opened ("design" equipment is usually not easy to disassemble/reassemble, and this one is a good example) I detect a dry leakage around C501, a slow discharge double layer capacitor (ELNA 0.22F/5.5V) used to backup memory (settings? radio presets?). This leakage has affected a few SMD around it and, more importantly, a lot of pins of IC500 (main controller) at side of pins 1-30. Solder looks dark and dirty. About 10 of these pins go directly to the S-Master controller IC301.
    I've cleaned the board thoroughly with IPA, toothbrush and cloth (the other side too!). Slightly brushed pins of IC500 with fiberglass brush, apply flux and ressolder all pins 1-30. Same with affected SMD resistors and caps. Replaced C501 with a new one.
    I'll wait for a few days of testing before celebrating it, but looks very promising. It's not the first time that I repair a failure caused by a leakage of this kind of special caps.
  • Carlos#2003%
    Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
    by Carlos#2003%
    Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
    02-15-2024, 07:52 PM
  • dkneyle
    Sony KDL-46HX850 Can't upgrade/update firmware
    by dkneyle
    Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
    Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
    09-25-2024, 10:44 PM
    Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
    This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
    09-06-2024, 05:27 AM
    Sony VAIO Duo 11 Hybrid (2-in-1) Duo 11 Specification for Upgrade or Repair
    This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
    09-06-2024, 05:30 AM
    Sony VAIO VPCEE3J1E/WI E Specification for Upgrade or Repair
    This specification for the Sony VAIO VPCEE3J1E/WI can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VPCEE3J1E/WI boardview and VPCEE3J1E/WI schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
