Compatible Tweeter Replacements ?
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Hello all, cant seem to find anything on these little tweeters but if anyone could help find replacements or compatible replacements here is the info of them.
    Technics SB-DV250 Cabinets
    Tweeter model:
    T6PH06D6
    D147C11
    So far I can only find that its a 19mm 4.7ohm tweeter but nothing else. Any info is much appreciated. Cheers
    • 30983
    Re: Compatible Tweeter Replacements ?
    so it's coil, not peizo?
    • rhomanski
      nowhere man
      • 5157
      • U S of A
      A pair seems to be for sale. http://www.ebay.co.uk/itm/Technics-S...IAAOSw7hRWQN9M . That would be what? About $35?
      sigpicThe Sky Is Falling
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Its a coil type bud.
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Cheers I could try and win them but I would like to try and repair the originals. If I cant them getting these.
          • rhomanski
            nowhere man
            • 5157
            • U S of A
            There's another pair on ebay in Germany. It's 90 euros though. There's a few places in the states that would have replacements but shipping would make it unreasonable. I found the owners manual, but it's in Russian. My Russians a little rusty now. I found a site in NZ that had one in English. That's all I can find. If you want to post pictures and tell what the problem is maybe one of us can help. I've repaired tweeter horns before by unwinding one turn of the voicecoil and resoldering it.
              • 30983
              try contacting cricklewood electronics in north london.
              they have a website
              • rhomanski
                nowhere man
                • 5157
                • U S of A
                Rather than repair those, I would rather see you get a pair of Boston Acoustic A40's. They were a good little bookshelf speaker from the early eighties. Sold quite well in the UK. I have a pair that have been refoamed. A great little speaker and a good value. If you check Ebay a company is even making new replacement woofers and tweeters even though they are way out of production. A testament to their quality and still popularity. They're made of thick MDF and a little heavy for their size. About 14" tall and 8" wide and about 7" deep.
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  Found a pair now thanks chaps, will let you know how it goes
                  • SluggerB
                    Can't find exact matching caps for replacements, what should I get to prevent video issues?
                    by SluggerB
                    I have an old Tivo. The Power Supplies are known to have caps that fail. Here are the caps that come with the original power supply:
                    I could not find replacement caps with the exact same specs. I followed an online guide and recapped the power supply with caps with these specs
                    The power supply now works, however the HDMI video is giving me eye strain. I don't know how a capacitor on a Power supply could impact an HDMI video signal, but it does, the Tivo interface has a flicker now and the color/brightness is off. So I want to get some new caps...
                    04-05-2024, 07:47 PM
                  • Blastsail
                    Help find compatible MOSFET from Asus FA506 DABXBMBAD0
                    by Blastsail
                    I have a coffee damaged asus laptop with shorted mosfet for vram. Trying to find replacement but I am struggling to. Markings are M3966M and I have attached image of mosfet. Schematics are available which say chip is a QM3966M6 but i am unable to find this chip no matter what combination of letters i put in. I can see there exists an m3966m3 chip but this appears to be the wrong size and markings are different.
                    I have attached schematic as well to help, mosfet is on page 44 of pdf. I do not know where to start to find a compatible mosfet so any help will be greatly appreciated....
                    05-07-2022, 07:35 AM
                  • withalligators
                    Looking for best replacements for Capxons, but can't find data sheets
                    by withalligators
                    Recapping the power supply board for a Samsung 305T monitor, everything is Capxon except 2 Rubycons. I can't find data sheets matching these online, so don't know what ripple numbers, impedence, etc, to look for. There are a few different looking GL series data sheet PDFs, but the listing that matches the capacitance and voltage is a much bigger case size. I've narrowed down selections with lead spacing and case diameter, and what's in stock at Digi-key
                    1 x Capxon 1000uf35v GL C720(is this a part number or batch number, can't find it anywhere) 105c
                    1 x Capxon 1000uf35v...
                    03-25-2022, 02:30 PM
                    by Vesko356
                    08-11-2023, 03:27 AM
                  • DrFalken
                    Dell Latitude 5530: damaged USB (type A) ports, cannot find replacements
                    by DrFalken
                    Yesterday a customer brought us a Latitude 5530 with 2 damaged USB ports (type A).
                    The ports are made by Singatron and, checking the measurements and soldering points, the model should be this one: https://www.singatron.com.tw/en/product/file/280177-1
                    I checked at RS, TME, Farnell but I didn't find this model
                    Where can I find them? Something compatible is also fine...
                    Thanks!!​
                    10-19-2024, 01:43 AM
