JBL PRX635 Schematics?
  • Yeoman
    • Jan 2015
    • 10
    I have an atypical problem with a JBL PRX635 amplifier.
    The HF amplifier seems to be oscillating causing the unit to heat
    up. The usual scenario with these units is replace shorted output mosfet devices. So I decided to change out the mosfets on the HF amp on the outside chance that it might cure the current draw, no change. If anyone out there has the schematics to share or has seen a similar problem with these class D amps please let me know.
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: JBL PRX635 Schematics?
    Might be one of the smaller pre-amp transistors/ICs causing the current draw. Look for an open copper trace, too.
    • Khron
      • Sep 2006
      • 1350
      • Finland
      Would the last result from among these be what you're looking for?
      http://elektrotanya.com/?q=showresul...oria=&kat2=all
      Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
        It does not show any Schematic.
        It is the same technical manual at JBL.
        • Longbow
          • Jun 2011
          • 623
          up.
          Well, is the audio output oscillating? At what frequency? Class D amplifiers "oscillate" at 100KHz or higher.
          This is an expensive way to troubleshoot. Besides, shorted FET's can be instantly confirmed with an ohm meter.
          Something that would cause heavy current draw would be a faulty PWM drive IC. This chip also makes sure that the output devices are not turned on simultaneously. One or more chokes are required at the output. They are heavier than most other parts and might have become loose on the board.
          Is it plugged in?
          • Khron
            • Sep 2006
            • 1350
            • Finland
            I'm starting to wonder just how different the electronics from the PRX635 are, from the ones in the PRX500 series - i DO have the service manual & schematics for those. The box in which the electronics are housed looks very similar...
            • Longbow
              • Jun 2011
              • 623
              Great, let's have a look at the output stage.
              Is it plugged in?
              • Khron
                • Sep 2006
                • 1350
                • Finland
                Here are the schematics i have - the main board (power supply & power outputs) and the modulator daughterboard.
                • Longbow
                  • Jun 2011
                  • 623
                  Now that's a serious Class D design! Not something you can slap together on your kitchen table.
                  Is it plugged in?
                  • Longbow
                    • Jun 2011
                    • 623
                    First, assuming the failed amplifier uses the same full bridge output, which of the 4 output transistors are hot? All of them? After confirming correct rail voltages, compare signals at U165 pin 2 and pin 4 (scope channel 1 and channel 2) with no input. Adequate dead time? Anything look fishy? Next, have a close look at the 2 pairs of level shifter/driver transistors, especially if only one side of the bridge is hot.
                    Is it plugged in?
                    • Yeoman
                      • Jan 2015
                      • 10
                      Walked away from this one for a bit. Thanks for the replies! Same amp as the prx500 series. The HF amp actually delivers audio to the compression driver however with no input signal and the speaker load removed r183 and r184 quickly get very hot. With a load connected the amp gradually heats up to the point of thermal shut-down.
                      Thanks Longbow I will take a close look at U165 and the related driver transistors. I suppose that if the mosfets are not switching correctly it could explain what I am seeing.
                      • Yeoman
                        • Jan 2015
                        • 10
                        Ok I seem to have solved it. C180 and C181 on this PRX635 unit are 0.22uF instead of 0.47uF as indicated on PRX500 schematic and also as are in place on the MF amp and LF amp in unit in question. I thought that this might explain the 52.9 kilohertz at 2.25 Volts PP that was present at TP150 (modulator schematic) with no input signal and no load. When I tacked .3uF across existing C180 and C181 the oscillation disappeared. Does not appear to roll off high end significantly with the extra capacitance.
                        • SCURISSIMO
                          Schematics Amplifier Qube PA-140
                          by SCURISSIMO
                          Hi all, I need the schematic of a QUBE PA-140 amplifier. Can someone help me?? Thank you.
                          01-01-2023, 05:45 PM
                        • MrCommunistGen
                          Polk Audio RTi100 Plate Amplifier won't power on and intermittently honks and buzzes
                          by MrCommunistGen
                          My childhood best friend was killed about 9 years ago. His parents are finally letting go of his things, and they offered me his Polk RTi100 tower speakers. The Polk RTi100 towers are one of a handful of designs from the early 2000s that is a full range 3-way tower with a built-in self-powered subwoofer. This is accomplished with a plate amp integrated into the speaker input panel.
                          I think they used them for a while, but they've been sitting for at least a few years now. After about 40 hours of driving to their house and back (both they and I have moved in the last 9 years) I got...
                          07-12-2021, 05:11 PM
                        • jinu_j
                          How to test Subwoofer Amplifier with only a multimeter
                          by jinu_j
                          Hi Folks
                          Need some advice on how to test a subwoofer amplifier if i have access to only a multimeter.
                          Problem
                          I have a Boston Acoustics active Subwoofer (soundware S). Its rated output is 200W. But the output i am getting is very low i can barely hear/feel it even if put the gain at max. I replaced all the capacitors in the Subwoofer amplifier but still no change.
                          Is there anyway to test this without getting an oscilloscope/Function generator to see if the fault is with amplifier, driver or the source??
                          Any advice would be appreciated...
                          08-29-2024, 02:05 AM
                        • Popalwali
                          Asus Nexus 7 2012 (ME370T REV 2.4) Schematics needed
                          by Popalwali
                          Hello Everyone,
                          I will be really grateful if someone shares schematics and if possible the boardview of the old Asus Nexus 7 (2012) Tablet. The motherboard is ME370T Rev. 2.4. Now I can find schematics for the Rev. 1.0 but I could not find the schematics for the Rev 2.4. I tried to look for similarities in the Rev. 1 but there are somethings missing, plus the board i have has nearly no component names printed on it which as a newbie makes pretty hard for me to locate things. Any assistance will be appreciated. Thank you.
                          08-25-2024, 11:28 AM
                        • Techmanx
                          Schematics Download Site
                          by Techmanx
                          If anyone needs schematic diagrams for any pro audio gear like what professional musicians use, such as guitar amps, power amplifiers, vintage tube amps, musical gear like keyboards, effects pedals, guitar wiring diagrams and service manuals, check out https://schematics.ca . I'm a road musician and an electronics tech and I got schematics for just about every piece of gear in my band from this site and they are free to download. It's always good to be prepared in case you fry something while on on the road, which always happens it seems. https://schematics-free.com has a lot of free audio schematics...
                          06-28-2023, 12:08 PM
