I have a kenwood sw-38ht that has stopped working with a blown fuse. i tried another fuse and with no input or output connected it blew instantly when i turned it on.
i looked the components over and do not see any damaged electronics. i checked resistance between positive and negative coming out of the bridge rectifier and it shows .2ohm. i have desoldered the bridge rectifier to be sure it was not shorted.
do you think it is the TDA7293V that has gone bad? would it be worth replacing, it is a fairly old amp.
attached is service manual, can pull the camera out if you want pics.
