Re: TC Electronic Studio Konnekt 48 revival
I had some issues with my Konnekt Live, after I plugged it in with the FW cable reversed. In my case the FW connection was good but the DAW indicator in the control panel was grayed out randomly. I narrowed down the issue to the FW chip. What I did was to "cook: its pins with a bit of solder, hot air station and some flux. I have had issues before with other machines where a reversed voltage caused a weak solder point to break but not the device itself. I guess I was lucky! Worked wonders! Thanks to Khron and everybody else!
). I do keep it powered on virtually all the time, because it (once again) takes a while to successfully finish booting up from cold - the 3.3v cap likely needs a refresh again, but I can't really be bothered. The thing's an utter PITA to take apart and reassemble...
