[Help Needed] Yatour YT-M06 (Pioneer 1) – Firmware or Schematic Request
  • EduCabral
    • Jul 2025
    • 4
    • Brasil
    I'm currently working on reviving a Yatour YT-M06 CD Changer Emulator module for use with a Pioneer 1 interface (specifically with a DEH-P5950IB head unit).
    While the unit is recognized as a CD changer, none of the USB, SD, or AUX features respond, which leads me to believe the firmware may be corrupted or incompatible.
    🔧 Details:
    • Model: YT-M06
    • Interface: Pioneer 1
    • MCU: Fujitsu MB89F202
    • Goal: Find a valid .bin firmware file or memory dump from a working unit
    I'm happy to attempt flashing, analyzing memory dumps, or doing hardware-level repair — but I need a valid starting point.
    https://github.com/EduardoCabral77/y...-firmware-help
  • EduCabral
    Help with Yatour YT-M06 Pioneer Interface (firmware or schematic needed)
    by EduCabral
    I'm currently working on repairing a Yatour YT-M06 multimedia interface (used with Pioneer head units). I'm looking for the firmware or schematic diagram to troubleshoot the board, as it's currently unresponsive.
    If anyone has any documentation, tips, or experience with this specific unit, I'd appreciate any help!
    Thanks in advance,
    Eduardo (from Brazil)
    07-09-2025, 11:57 PM
  • Daniel Larsson
    Firmware file for Marantz NR1501 needed
    by Daniel Larsson
    I picked up a Marantz NR1501 that the seller said did not produce any audio, but was starting up just like normal. This was indeed the case and the hunt for damaged components started.
    After confirming all voltages and replacing all caps on this godforsaken HDMI-board I finally got sound from the AUX input, but all digital inputs are still dead.
    The service menu shows no DSP version so I desoldered IC1604 that should have the serial flash DSP firmware on it and made two dumps that turned out identical.
    The content of these seems to be useless as far...
    05-23-2025, 04:11 AM
  • neo2010
    Lenovo X1 Carbon Gen 2 Touchscreen Firmware needed
    by neo2010
    I accidentally flashed the wrong firmware to my Lenovo Laptop Touchscreen. Now it is not recognized anymore in Windows 10. With Linux, I get the Device Listed as ELAN 04f3:000b USB device. I have modified the original Lenovo Flash Tool and tried other Firmware bin files but without success.
    The screen is the WHQD version. Can anyone provide a firmware bin file to reflash the touchscreen controller? As it seems that the controller is in recovery mode.
    Thanks in advance
    05-23-2024, 08:04 AM
  • gkoukoul
    TV Felix FXV-4221 - firmware needed
    by gkoukoul
    Hello!
    I have a Felix TV that turns on, shows the "FELIX" logo then shows a "WISDOM SHARE" message and doesn't do or respond to anything else.
    I'm assuming a firmware flash will fix it.
    I can't find the firmware file though, anyone has it please?
    11-12-2024, 12:02 PM
  • Sam Scarbo
    Blomberg DV17600W laundry dryer MCU firmware needed. Please help!
    by Sam Scarbo
    I'm helping my brother to fix his Blomberg laundry dryer. He called a repair guy to have a look and the repair guy said the control board is faulty. They said the replacement board costs $400. Too expensive! 😨 My brother asks me to take a look. He has checked the door switch and thermal fuse, etc., and those seems fine.
    After plugged to mains, there is no display. There is just a clicking sound from the buzzer, like one click per second. No other response.
    I suspect the firmware inside the MCU (ATMEGA64A) got corrupted. Can someone in this forum by any chance provide...
    07-21-2024, 05:24 PM
