Sherwood R-300 repair assist pls.
  • DanR
    • Jan 2014
    • 5
    I have this Sherwood R-300 on the bench, with 2 blown fuses near the Line Transformer. Fuses are both 750ma @ 125v, so they are not for the outputs. Does anyone have a schematic for this unit? Or is anyone familiar with it enough to say what source these fuses feed? The output transistors are not shorted.
    master hoarder
    • May 2008
    • 12175
    Re: Sherwood R-300 repair assist pls.
    I'm not familiar with this amplifier (or others too much either), but it sounds like this is a fuse for some kind of standby power supply/transformer. If no one posts a schematic or service manual in a few days, post some pictures and maybe we can figure it out from there. 750ma @ 125v seems to low to be a fuse for the main transformer (unless this is like about 20W/channel amplifier, but I doubt it).
      Surface Mount Fuses Fundamentals Datasheet
      TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
      TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
      10-07-2024, 06:07 AM
      ATI R300 / Radeon 9700 Schematic & Board View
      ATI's R300 GPU uses the R300 architecture and is made using a 150 nm production process at TSMC. With a die size of 215 mm² and a transistor count of 110 million it is a medium-sized chip. R300 supports DirectX 9.0 (Feature Level 9_0). Modern GPU compute technologies are not available. It features 8 pixel shaders and 4 vertex shaders, 8 texture mapping units and 8 ROPs. Due to the lack of unified shaders you will not be able to run recent games at all (which require unified shader/DX10+ support).
      The Radeon 9700 was a...
      10-01-2024, 01:13 PM
    • Sik_6ty_Sixx
      HH Scott Model A510 Stereo Integrated Amplifier/ Graphic EQ - Blowing fuses in the LEFT speaker channel only. Any Help???
      by Sik_6ty_Sixx
      So like the title says, I have an old Stereo Receiver/Amplifier that I picked up from the goodwill, it's a HH Scott Model A510. When I first got it home it had zero output. Opened it up, notice the fuses are missing. Pop in 2 new fuses (AGC4A 250V) and try again, within 5 seconds the L channel fuse POP! I don't see any visible indications of damage or arc burns on the PCB, no popped resistors or diodes, no burnt traces or blown out caps. So I decide to just try another new fuse, POP. Swapped around my R and L speaker wires, and checked the integrity of all wires and connections. Everything looks...
      02-18-2025, 05:06 AM
      Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
      12-14-2023, 07:45 PM
    • acedogblast
      Power supply for main amp blows fuses after replacing filter caps.
      by acedogblast
      Hello I have a Marantz sr5012 that I have been repairing. After I have replaced the 2 main filter caps the 2 fuses for the power amplifier blows. The original capacitors are ELNA LAO 10,000uF 71V and the replacements are Nichicon LKS 10,000uF 80V.
      I assume a short circuit connection has occurred so I set my multimeter to measure ohms across the 2 fuse connections and both read 55 Kilo-ohms so I assume that is ok.
      I am certain that I do not have any bridges on my soldering and after probing around I do find a temporary 0 ohm reading when probing across the positive and negative...
      02-27-2023, 05:11 PM
