Beomaster 5500
  • Colliman
    • Sep 2024
    • 10
    • SWEDEN
    Beomaster 5500
    Hi there, this is my first post in this forum.
    I have a service question.
    The receiver Bomaster 5500, do not react on IR controller or buttons on the receiver.
    When I connect it, the "NO TIMER" and "TAPE" plus an J in the display.
    I have measured all voltage around the IC´s, and I got the relay to switch on.
    Does anyone get a clue where I can get some help, where to look next.
    I try to upload the schematic, but this is more a question to someone how had experience with Bo.
  • R_J
    • 9535
    One thing to check would be the 3V backup battery listed on page 3 as G1 if it is bad, it my effect the operation, if it is dead it acts like a short and can affect the reset, try removing it and see if it starts to work.
    After that check all the supply voltages especially the +5V
    • Colliman
      • Sep 2024
      • 10
      • SWEDEN
      Hi R_J Thanks for the reply.
      Checked that one.
      3.2 V.
      I think it's the CPU that's freaking out.
      Have to check the ALE pin for a steady 1MHz.
      Had hope the "J" reading on the display was a fault code.
      But it's probably the CPU that give some static display not working.
      And I had hope for an easy repair.
      • CapLeaker
        Leaking Member
        • 8162
        As R_J already mentioned: check your power supply rails and that all the IC's around and including the main IC is getting fed proper power. After that, I would check some data pins between the main IC and the RAM, ROM and the address latch, looking for activity on the oscilloscope. I think the crystal oscillator is running, otherwise you wouldn't get anything at all.
        • Colliman
          • Sep 2024
          • 10
          • SWEDEN
          Thank’s CapLeaker for the tips.
          Checked all power rails, but will do it again.
          Thanks for the tip about the crystal.
          Hopefully it's not the display driver that faulty giving the light.
          • Colliman
            • Sep 2024
            • 10
            • SWEDEN
            Found out the IC 1 8031 was the problem, waiting for a used one to replace.
            Hopefully that will the only fault left.
            But you never know.....
            • CapLeaker
              Leaking Member
              • 8162
              Was it getting a bit warm?
              • Colliman
                • Sep 2024
                • 10
                • SWEDEN
                No, but I never checked that seriously.
                Can check that before changing.
                • Colliman
                  • Sep 2024
                  • 10
                  • SWEDEN
                  Got 2 used 8031 from a friend for a bargain.
                  Also got a 40 pin socket, so I can change quickly.
                  Have de-solder the IC and solder the socket.
                  Enough for to day.
                  • Colliman
                    • Sep 2024
                    • 10
                    • SWEDEN
                    After changing the 8031 I still have same indication on the display. So next on the list is M 5450 display driver.
                    • Colliman
                      • Sep 2024
                      • 10
                      • SWEDEN
                      Contacted a friend that repair B&O.
                      He said there are used to be two frequent problems.
                      Bad soldering in some of the 600 solder points, a nice job to conquer.
                      Or the ROM.
                      So I will meet him, and test my cards using the new ROM.
                      Hopefully that will be the problem.
                      • diamon
                        Changing model number 5500 to 5510
                        by diamon
                        I would like to place a Dell Latitude 5500 (black color) motherboard into a Dell Latitude 5510 (silver color) chassis .
                        How can I change the model number of this laptop?.
                        When you're entering the bios (F12), you see in the left corner Latitude 5500, I would like to have this changed into Latitude 5510
                        I have already edited the 5500 bios bin file with HxD, and changed the 5500 into 5510, but after re-flashing and soldering the chip back, the name in the left corner is still Dell Latitude 5510 (have entered the ServiceTag of the 5510 chassis).
                        Have uploaded the original...
                        06-19-2025, 03:25 PM
                        DELL G5 5500 Notebook Specification for Upgrade or Repair
                        This specification for the DELL G5 5500 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5500 boardview and 5500 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL G5 5500 Notebook is...
                        09-06-2024, 11:40 PM
                        09-06-2024, 10:20 PM
                        09-06-2024, 09:30 PM
                        09-06-2024, 08:10 PM
