Please help indentify the chip on Sony WH-1000XM4 battery board
  • picouser
    • Oct 2017
    My Sony headphone WH-1000XM4 is damaged by water, and the chip circled is totally ruined. I found this photo by Google but can not read it. By any chance someone here know what chip it is? Thanks in advance!
  • petehall347
    • Jan 2015
    • 4440
ID:	3179757 https://electronics.stackexchange.co...with-four-pins
    • spleenharvester
      Tower T548006 battery, fault on BMS board
      by spleenharvester
      I have two of these spotwash machines. They are portable systems that use a 12V power tool battery consisting of three 18650 cells. One of the batteries recently failed. 12V appears at the terminals but there appears to be a fault condition - machine flashes LEDs when you attempt to power up. When you plug in the battery directly (the machine charges through a USB-C port, but there is a second USB-C port on the battery itself for some reason that can also be used for charging), the green LED lights and a dim red LED lights next to it solid. By comparison, a working battery will flash green only....
      10-04-2025, 06:33 AM
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
      Another project idea for a battery bought from Battery Hookup with a good BMS board
      https://batteryhookup.com/products/n...-2900mah-cells
      One note these battery packs are below 10 volts and the BMS protection board has locked them off from having any voltage on the BMS output wires I have tested three of them so far and voltage is around 8 volts it not an issue because it testing about 9.2 amp hours
      The price of this offer has gone up sense I bought these two boxes
      I bought two boxes of these batteries but there is a catch to the these battery packs
      The BMS protection board does work but it...
      07-31-2022, 04:07 AM
      DELL XPS 9365 Hybrid (2-in-1) 13 Specification for Upgrade or Repair
      This specification for the DELL XPS 9365 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 9365 boardview and 9365 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL XPS 9365 Hybrid...
      09-06-2024, 05:40 AM
