Realistic 31-2020A 10 band Equalizer HUM problem
  • flinx
    • Aug 2010
    • 132
    I have had this for about 23 years, a few years ago it developed a hum. At the time I was not interested in or had any idea how to fix it. Now I would like to get it working right. I googled for information and found a thread on another forum of someone with the same problem. The last entry from 2010 was that the OP was going to recap the power supply. There are no further entries as to whether this worked or if the person ever got theirs working right.
    I recapped the power supply in this unit and there was no improvement in the hum. The hum gets worse if you push in the EQ record, IMX expander, Tape monitor 1 or 2, or tape dubbing 1 or 2, the hum is reduce a small amount by pressing the EQ bypass button. The hum (according to the spectrum display) is centered around 120hz. Moving the sliders for 125hz or around it does not have any effect on the hum. The hum is present whether anything is connected to the input or not.
    I hooked up my oscilloscope and did some random measurements. I found that there is either a sign wave present almost everywhere I tested, or a sawtooth wave, with the sawtooth wave being more prevalent.
    Zoomable schematic:
    31-2020A
    Attached is a PDF file of the Schematic.
    The scan is the best scan I can get as the one in the back of the book is rather small and detailed.
    "...off the record, unnamed government sources
    alluded to unsubstantiated innuendos about
    alleged indiscretions and insinuated that they
    are rumored not to be without basis for further
    speculation..."
  • lexwalker
    • Feb 2011
    • 307
    • Malaysia
    Re: Realistic 31-2020A 10 band Equalizer HUM problem
    Zoomable schematic:
    31-2020A
    Well, the hum could have originated from a broken common GND/Earth line as well (since the hum is around the multiple of the mains frequency). You may want to look for signs of solder cracks (cold solder joints) and internal broken wires. Also what were the brand/model/series capacitors used for replacing the original ones?
    • Longbow
      • Jun 2011
      • 623
      Where exactly is the hum? At the input to the regulators, at the output of the regulators? Not on the power rails at all??
      Is it plugged in?
      • Longbow
        • Jun 2011
        • 623
        I think he's safe to assume that power supply capacitors are not causing the hum, especially if the symptom did not change. And more especially since this unit uses a non-switching power supply which does not make extreme demands upon the quality of the filter capacitors.
        Is it plugged in?
          120 Hz (twice the line frequency) is what you get as the AC ripple on the DC out put after the full wave rectifier circuit.
          So look at the AC ripple at the filter caps. You may also have ground loop, bad grounding of the circuit, etc. Make sure to tighten up all the board mounting screws since it may use as circuit grounding.
          • flinx
            • Aug 2010
            • 132
            here are the measurements of the transistors in the power supply and diode information:
            zener d504 gza15(z) rated min 14.85vdc max 15.60vdc
            q505 d288 y-923
            e 14.95vdc
            b 15.52vdc
            c 21.74vdc
            zener d503 qza22(x) rated min 20.8vdc max 21.8vdc
            q504 a614 y-922
            e 21.56vdc
            c -24.54vdc
            b -21.27vdc
            zener d502 qza22(x) rated min 20.8vdc max 21.8vdc
            q503 d288 y-923
            e 20.68vdc
            c 24.43vdc
            b 21.27vdc
            I checked both resistors r511 and r512 at the request of someone (unsoldered one leg) and they tested about 4.4k. I resoldered them and then checked all the power supply soldering. I powered it up and noted that the display did not show a hum, but the power led was dim. I was about to wonder what was going on when I noticed the tiny wisp of smoke coming off the power supply. I shut it off and found that the resistors were hot. I double checked the soldering again and verified all capacitors are installed correctly. I powered it up again and got the same results. something is shorted now. I am going to go over it again here in a few minutes.
            speculation..."
            • flinx
              • Aug 2010
              • 132
              I found that when I had resoldered one point, from the angle I was sitting I did not see that 2 pads that are not joined got joined.
              I fixed that and powered it up with no more smoke, but still a hum. I checked the 2 resistors again and they were now measuring higher, so I replaced them. powered it upain, and... The display maxed out and there was a clicking sound. NOW WHAT.
              Powered it off and on again and no hum, but no display... The unit passes music, but IMX expander sounds distorted when enabled.
              Now the voltage coming off of the transformer at C516 is only about 1.3vac
              While pondering this I noted that I could smell transformer, and went to touch it. It was really hot 140°f.
              sighâ„¢ I do not know why I even bother working on transistorized stuff.
              Just going to leave it alone for today.
              speculation..."
              • ben7
                Capaholic
                • Jan 2011
                • 4059
                Could be that there is a short, overloading the transformer.
                Perhaps you have a bad rectifier diode, or a leaky diode. (leaky electrically, not physically!)
                Muh-soggy-knee
                • Longbow
                  • Jun 2011
                  • 623
                  That would be a problem. Desolder either pin 4 or 5 of the transformer and check the secondary. If OK, find the short in the diode bridge or in the regulator. Q505 is responsible for the operation of the display among other things.
                  You mean you prefer to work on tube gear?
                  Is it plugged in?
                  • flinx
                    • Aug 2010
                    • 132
                    Originally posted by Longbow
                    That would be a problem. Desolder either pin 4 or 5 of the transformer and check the secondary. If OK, find the short in the diode bridge or in the regulator. Q505 is responsible for the operation of the display among other things.You mean you prefer to work on tube gear?
                    Yes, so far tube gear is more forgiving.
                    Went to a hamfest today and what did I find? The Optimus version of this same EQ. It has one issue that I will not mess with, the 16khz led display does not work, but the 16khz channel does. So in to the parts bin goes my old one. I may try to work on it later.
                    speculation..."
                    • Longbow
                      • Jun 2011
                      • 623
                      Now that's the spirit!
                      Is it plugged in?
                      • flinx
                        • Aug 2010
                        • 132
                        I suck... I admit it.
                        I will most likely work on it again, but not this week.
                        speculation..."
                          HP Pavilion Wave Pavilion Wave Desktop - 600-a030na Pavilion Wave i3-6100T Specification for Upgrade or Repair
                          This specification for the HP Pavilion Wave Pavilion Wave Desktop - 600-a030na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Wave Pavilion Wave Desktop - 600-a030na boardview and Pavilion Wave Pavilion Wave Desktop - 600-a030na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                          09-12-2024, 03:44 PM
                          HP Pavilion Wave Pavilion Wave Desktop - 600-a103na Pavilion Wave i3-7100T Specification for Upgrade or Repair
                          This specification for the HP Pavilion Wave Pavilion Wave Desktop - 600-a103na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Wave Pavilion Wave Desktop - 600-a103na boardview and Pavilion Wave Pavilion Wave Desktop - 600-a103na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                          09-12-2024, 02:00 PM
                          HP Pavilion Wave 600-a055cn Pavilion Wave i5-6500T Specification for Upgrade or Repair
                          This specification for the HP Pavilion Wave 600-a055cn can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Wave 600-a055cn boardview and Pavilion Wave 600-a055cn schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                          HP Pavilion Wave 600-a102ng Pavilion Wave i3-7100T Specification for Upgrade or Repair
                          This specification for the HP Pavilion Wave 600-a102ng can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Wave 600-a102ng boardview and Pavilion Wave 600-a102ng schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                          HP Pavilion Pavilion Wave Desktop - 600-a059na Pavilion i5-6400T Specification for Upgrade or Repair
                          This specification for the HP Pavilion Pavilion Wave Desktop - 600-a059na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Wave Desktop - 600-a059na boardview and Pavilion Pavilion Wave Desktop - 600-a059na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
