Kenwood Powered Subwoofer SW-38HT
  • mactypetim79
    • Oct 2013
    • 5
    Hello everyone!
    One of my pending projects is a SW-38HT Kenwood powered subwoofer. Unfortunately, during my pre-sound check, I noticed that a capacitor was blown. Not just busted or bulged but burned to a crisp, making identification impossible. Anyone have access to a schematic, or perhaps can figure what the value of this cap would have been?
    http://www.flickr.com/photos/107059463@N02/10565017734/
    http://www.flickr.com/photos/107059463@N02/10565023874/
  • kaboom
    "Oh, Grouchy!"
    • Jan 2011
    • 2507
    Re: Kenwood Powered Subwoofer SW-38HT
    Does this unit work fine otherwise?
    That cap, being near the wires from the transformer, suggested to me that it was for noise suppression of the bridge rectifier.
    The schematic confirms this. Both C31 and C32 are connected as such. You can use it without those caps; there may be slightly more noise on a nearby AM radio as a consequence.
    Those ceramics are underrated for such use. There should really be two polyester or (larger) polypropylene caps for such duty.
    Remove C32, on the other AC leg from the transformer and the other side of that connector, and try it.
    "pokemon go... to hell!"
    EOL it...
    All style and no substance.
    guilty,guilty,guilty,guilty!
    guilty of being cheap-made!
    • mactypetim79
      • Oct 2013
      • 5
      No, haven't turned it on yet - never got to that point. For audio equipment I do a visual check first and blow it out with an air compressor. Thank you for getting back so quickly. Did not expect that. I'll try your suggestions at work this Thursday.
      -Tim
      • kaboom
        "Oh, Grouchy!"
        • Jan 2011
        • 2507
        -Tim
        You're welcome.
        I got sort of lucky and found that service manual rather easily. More so than some others, which after a "google oogle," can be rather frustrating...
        EOL it...
        • mactypetim79
          • Oct 2013
          • 5
          Just tried the subwoofer and it thumps fine, though I couldn't isolate the sub enough to really tell if there was more noise, etc. I miss the older Kenwood receiver I used to use for testing! Sound seemed fine however with no distortion that I could hear.
          I did remove that 2nd cap (C32), and there seemed to be no extra distortion on my AM shop radio. Now, I have to make a judgement call - is it ok to resell the unit now without those caps or should I replace and upgrade them?
          • kaboom
            "Oh, Grouchy!"
            • Jan 2011
            • 2507
            Aha- didn't know that you were planning to sell it.
            Those caps are/were there for possible noise issues with weak signal reception. Which may be why you didn't notice increased interference.
            I'd be tempted to replace them. I'll have to look, I may have some .047 100V MLCCs to give you. I've used these as SMPS snubbers and audio amplifier Zobels w/o issues. They're more than adequate for your application.
            Edit:
            I just checked the caps I have. I no longer have any .047 100V. I do have .047 50V.
            As the two large electros are also 50V, it follows that each leg from the transformer does not exceed 35V AC. So C31 and C32 can be replaced with good 50V caps.
            If you're still interested, let me know...
            EOL it...
            • mactypetim79
              • Oct 2013
              • 5
              Its been a busy month... finally got back to these projects after I got another receiver in with blown caps, and I just went to digikey and ordered for both units before I remembered your post.
              Hold on to those caps. If you end up not using them, I may ask if something REALLY nice comes in
              • pfl
                ElectroVoice ETX-18SP (powered Subwoofer) damaged after lightning strike
                by pfl
                Hello Everyone.
                This powerful amplified subwoofer doesn't make any sound after lightning striked near the house were it was plugged in.
                It consists in :
                • a power board were the full H bridge class D amplifier and main power rails are located
                • a preamp board (ref. F.01U.299.771) receiving 2 symetrical inputs(IN1, IN2), a digital chain (A-D converter -> Digital Signal Processor -> D-A converter) and a micro controler in charge (at least) of the human interface (lcd display and 1 rotating button)
                Power rails are ok.
                human interface is working fine
                Input levels are...
                01-23-2024, 10:21 AM
              • rustinjust
                Please help, subwoofer connected to tv, read description below
                by rustinjust
                I've got a subwoofer that I've had for nearly 20 years, it did come with a basic remote which I've lost. It's a generic make of subwoofer, I can't see a brand sticker on it. It comes with 2 speakers.
                Question recently I've connected it up to my tv which has greatly improved the sound on my tv, however I'd like to be able to mute the subwoofer when ads come on or just mute it when the phone rings etc. I tried using a cheap all in one tv remote on the subwoofer and the volume button would only work to increase volume but not turn it down or mute it
                Is there a way of...
                10-28-2023, 07:09 AM
              • rustinjust
                Please help, where can I get a remote for my subwoofer?
                by rustinjust
                I’ve got a subwoofer that I’ve had for nearly 20 years, it did come with a basic remote which I’ve lost. It’s a generic make of subwoofer, I can’t see a brand sticker on it. It comes with 2 speakers.
                Question recently I’ve connected it up to my tv which has greatly improved the sound on my tv, however I’d like to be able to mute the subwoofer when ads come on or just mute it when the phone rings etc. I tried using a cheap all in one tv remote on the subwoofer and the volume button would only work to increase volume but not turn it down or mute it
                Is there...
                10-28-2023, 03:43 AM
              • imaddicted2u
                Soundstage powered 12" home subwoofer
                by imaddicted2u
                My Son sent me these pics. Capacitor blowed up...any thoughts on what the value might be?
                Not much left of it to identify but he says the can is same size as 220mfd 25V caps on the board. Safe bet to try to replace with one of that size?
                There is no model number on the box....
                05-15-2023, 11:16 PM
              • kotel studios
                Lantec PULSE 386 subwoofer - no audio output
                by kotel studios
                Hi
                I have this Lantec PULSE 386 subwoofer I got a while back laying around awating repair for quite some time. Sadly it's missing it's original speakers which it came with.
                After plugging in the mains, the LED on the volume controller lights up. When I plug in the 3.5" jack cable to my soundcard (confirmed to work), I get no audio on the subwoofer (nor the speaker jack at the back).
                The PCB is quite simple. There is a UTC4558 amp and two D6282 audio amps. When I put my finger on the UTC4558 I can see and hear the speaker "fart". Although, the left...
                11-29-2025, 04:15 AM
