Crown K2 Amplifier
  • Maxxarcade
    • Jul 2006
    • 973
    Crown K2 Amplifier
    I have 3 of these amps at work that I need to repair, they go into shutdown after power on. Does anyone have the schematics for this model?
    I was able to get one of them to stay on by unplugging one of the amp boards, and I'm hoping to at least combine parts to make one or two of them work. I would rather just fix them all though.
  • mbates14
    • May 2005
    • 169
    Re: Crown K2 Amplifier
    ive worked on a shitload of crown power amplifiers.
    them are NOTORIOUS for output transistor failures. when they fail, they take out the drivers, couple of diodes, and a few resistors. gotta do some DMM testing extensively in those units.
    • MrCommunistGen
      Polk Audio RTi100 Plate Amplifier won't power on and intermittently honks and buzzes
      by MrCommunistGen
      My childhood best friend was killed about 9 years ago. His parents are finally letting go of his things, and they offered me his Polk RTi100 tower speakers. The Polk RTi100 towers are one of a handful of designs from the early 2000s that is a full range 3-way tower with a built-in self-powered subwoofer. This is accomplished with a plate amp integrated into the speaker input panel.
      I think they used them for a while, but they've been sitting for at least a few years now. After about 40 hours of driving to their house and back (both they and I have moved in the last 9 years) I got...
      07-12-2021, 05:11 PM
    • jinu_j
      How to test Subwoofer Amplifier with only a multimeter
      by jinu_j
      Hi Folks
      Need some advice on how to test a subwoofer amplifier if i have access to only a multimeter.
      Problem
      I have a Boston Acoustics active Subwoofer (soundware S). Its rated output is 200W. But the output i am getting is very low i can barely hear/feel it even if put the gain at max. I replaced all the capacitors in the Subwoofer amplifier but still no change.
      Is there anyway to test this without getting an oscilloscope/Function generator to see if the fault is with amplifier, driver or the source??
      Any advice would be appreciated...
      08-29-2024, 02:05 AM
    • UserXP
      Mackie CR4 amplifier no sound
      by UserXP
      Hi, people.
      I've got an amplifier assembly from Mackie CR4 parts. It's just an amplifier, there was no speaker housing, so I used my set of CR4s to test it.
      Anyway, upon connecting everything and hooking the "new" amplifier to an audio source, the sound played clearly and strongly for the first ten seconds. I was happy it was working. Then the sound started to fade out during the playback until it was no more. After it had "dropped to zero", there were two very short intervals of sound playing at the normal volume, as if the amplifier was trying to...
      10-17-2020, 05:06 PM
    • mikey5791
      Help on car amplifier only one channel works
      by mikey5791
      Hi all forum members,
      Fyi, i have been working on this old model PCT-4082 (4 channel car amplifier). The owner said only one channel is working.
      My initial finding is this amp originally use Toshiba 2SA1943 and 2SC5200 transistor for its output but after opening the top casing i found it used Toshiba A1941 (pnp)and C5198(npn). I desoldered all the 4 pairs transistors and found 1 piece A1941 open(tested "OL" on all legs) and replaced the 1st pair with 2SA1943 and 2SC5200, thats why you can see in the picture it is the bigger size transistor. The other A1941 and C5198 all...
      08-06-2025, 10:36 PM
    • Francesc V.
      Rotel RSX-1056 amplifier. Troubleshoot a noisy channel
      by Francesc V.
      Hi:
      I've realized that one of the channels of this amplifier has no proper sound.
      This is the signal at the speakers output.
      As long as the audio coming in to the amplifier board (blue) looks ok although with some noise due to the wire, I think that there's nothing to look at the preamp section.
      Now, I could start looking at components to see whether I find the guilty one.......but I would rather prefer to ask for advice. Here there is the amp. schema. Which points would you check with the oscilloscope to gather...
      07-15-2025, 01:33 AM
