Vox mini 3 amp
  • midibob
    • Nov 2008
    • 285
    #41
    Re: Vox mini 3 amp
    Hi Ben7,
    I didn't want to complicate the board more than needed although I suppose you only have to click a button on the CAD software, also I didn't want too much exposed area of copper that might touch anything. As both speaker leads are at half the rail voltage the likelihood of a possible short to ground would destroy the chip.
    Soldering was done by hot air gun so not sure if you count that as hand soldering?
    Midibob
    • Thomt
      • Aug 2013
      Re: Vox mini 3 amp
      Hi, I'm wondering if it's possible to add a 1/4" line out to my Vox Mini 3. The headphone out is very unreliable, crackles, pops and cuts out. Any help would be appreciated.
      • midibob
        • Nov 2008
        • 285
        #43
        Re: Vox mini 3 amp
        I suppose you could just extend the connections from the existing jack socket as it looks like it just signal and ground. I don't know what the voltage level is presented there so you may need an attenuator.
        I wouldn't recommend taking it off of the speaker connections as they both sit at half rail potential and if either of them get grounded it will destroy the output chip.
        Can't really give you more info than that as I've never looked into that side of things. Have you tried squirting a small amount of switch cleaner into the existing socket, maybe it's just dirty.
        Good luck
        Midibob
        • Allante666
          • Oct 2013
          Re: Vox mini 3 amp
          HI, I hope im not too late to jump in on this thread but am hoping these midibob boards are still available? if so how do i go about getting one, well, four.? Only just joined so cant message anyone as yet but would like to kow more about this mini 3 issue. Andy
          • midibob
            • Nov 2008
            • 285
            #45
            Re: Vox mini 3 amp
            Hi Andy,
            Yep, made up a few ready for anyone that needs them.
            I'll try sending you a PM with my email address and we can correspond.
            Cheers
            Midibob
            • Allante666
              • Oct 2013
              Re: Vox mini 3 amp
              Thanks Bob, just replied to your email, let me know if you dont get it.
              • b0Rn2bL8
                • Jan 2014
                • 6
                Re: Vox mini 3 amp
                Hi Bob,
                Total novice here, I have the same symptoms: Vox mini3 with no sound from the speaker, but phones are OK. I need to learn how to test for sure whether I have the same problem and can, hopefully, use the same solution.
                Thank you in advance
                Andrei
                • midibob
                  • Nov 2008
                  • 285
                  #48
                  Re: Vox mini 3 amp
                  Hi Andrei,
                  The quick check is to test the resistance between the speaker leads and ground.
                  Make sure it's turned off and then check the resistance with the speaker disconnected from both leads to a ground on the circuit board.
                  If the chip's OK, which it probably isn't on yours, both leads (red and black) should measure over 100K Ohms and probably nearer 1M ohms to ground. If either of them measure under 100 Ohms then you know the chip has blown.
                  On these amps don't assume the black speaker lead is ground, as it isn't, and I suspect many people blow the chips trying to add more speakers.
                  If it's blown you then need to decide how you want to repair it. All documented in the thread.
                  I still have spare daughter boards if you need one but I wouldn't recommend anyone without reasonable soldering skills to attempt to fit one.
                  Let me know how you get on.
                  Good luck
                  Midibob
                  • b0Rn2bL8
                    • Jan 2014
                    • 6
                    Re: Vox mini 3 amp
                    Hi Bob,
                    Thank you for the prompt reply and the thorough answer.
                    I will follow your instructions and let you know what I find out.
                    Andrei
                    • b0Rn2bL8
                      • Jan 2014
                      • 6
                      Re: Vox mini 3 amp
                      Hi Bob,
                      Here is my progress so far:
                      bought a multimeter
                      read the manual
                      read the tutorial (learned that "OL" stands for "Open Loop", not "Zero Load"
                      disconnected the speaker
                      disconnected both an AC adapter and a Battery Pack
                      switched the power to "Stand By" (there is no "Off" position)
                      white speaker lead reads .987 on at 2MΩ setting
                      black speaker lead reads 22.8 on at 200Ω setting
                      It looks like the amp chip is blown and your daughter board is the solution I need.
                      Please advise,
                      Andrei
                      • midibob
                        • Nov 2008
                        • 285
                        #51
                        Re: Vox mini 3 amp
                        Yep, that would appear to be the case as that's the usual problem.
                        I can send you a board but I suspect you'll need to find someone to fit it for you.
                        I could do it here but the postage costs each way to the UK would be prohibitive I expect.
                        I'll PM you the details.
                        Midibob
                        • b0Rn2bL8
                          • Jan 2014
                          • 6
                          Re: Vox mini 3 amp
                          Hi Bob,
                          I have only rudimentary (pre-PCB) soldering skills.
                          I'm interested in improving them and learning new ones, so -
                          What tools would someone attempting this job need? Would a standard 25-watter do?
                          Can you recommend any tutorials?
                          Andrei
                          • midibob
                            • Nov 2008
                            • 285
                            #53
                            Re: Vox mini 3 amp
                            I'm sure you'll find many tutorials on Youtube. I can't recommend any specific ones as I've never needed to look.
                            I've sent you a PM with my mail address. If you reply I'll send you the instruction sheet so you can see what's involved.
                            Midibob
                            • b0Rn2bL8
                              • Jan 2014
                              • 6
                              Re: Vox mini 3 amp
                              thank you Bob
                              • rhall010861
                                • Mar 2014
                                Re: Vox mini 3 amp
                                Hi midibob, i have a semi dead vox mini3 too, do you still have any daughterboards left?
                                • midibob
                                  • Nov 2008
                                  • 285
                                  #56
                                  Re: Vox mini 3 amp
                                  Yep,
                                  I'll send you a PM.
                                  Midibob
                                  • Aimjam
                                    • Feb 2014
                                    Re: Vox mini 3 amp
                                    midibob. Very interesting thread, just spent the weekend reading it and trying to fix my own Vox Mini 3 without much success. Would you be able to send me details of the daughter board as well. Much appreciated Aimjam
                                    • midibob
                                      • Nov 2008
                                      • 285
                                      #58
                                      Re: Vox mini 3 amp
                                      Hi Aimjam,
                                      I'll PM you.
                                      Midibob
                                      • rhall010861
                                        • Mar 2014
                                        Re: Vox mini 3 amp
                                        Thanks to Midibob I now have a working Vox Mini 3, had been intermittant, then no power amp at all. Now with daughterboard fitted, all ok - patience and magnifying glasses helped!
                                        • Aimjam
                                          • Feb 2014
                                          Re: Vox mini 3 amp
                                          Midibob. Thanks for the daughter boards and the instructions how to fit. Very easy to follow and the Amps are now working. Thanks again your work is spot on Aimjam
                                          • ugamazing
                                            Best place to source RAM chips? 8GB 820-00850 boards to 16GB or 32GB
                                            by ugamazing
                                            I'm looking to upgrade several 8GB 820-00850 boards to 16GB or 32GB for personal use. I am curious what the best practice and process is for sourcing new replacement chips, and what vendor(s) you guys prefer? Another question is, how do I find compatible chips and their corresponding part/model numbers? For example, in the 820-00850 schematic, the DDR chip U2600 model listed (EDFB232A1MA) corresponds to 1x32GB chip. Of course, I would need 4x8GB chips to replace the 4x2GB chips currently on the board. How do I find compatible 8GB chips? Is it as simple as searching "BGA178 8GB 2133"...
                                            08-31-2022, 07:34 AM
                                            HP 260 G2 Desktop Mini PC i3-6100U Specification for Upgrade or Repair
                                            This specification for the HP 260 G2 Desktop Mini PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the 260 G2 Desktop Mini PC boardview and 260 G2 Desktop Mini PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-12-2024, 03:36 PM
                                            HP Stolní počítač 260 G3 Mini i5-7200U Specification for Upgrade or Repair
                                            This specification for the HP Stolní počítač 260 G3 Mini can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Stolní počítač 260 G3 Mini boardview and Stolní počítač 260 G3 Mini schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                            09-12-2024, 02:20 PM
                                            09-12-2024, 02:15 PM
                                            HP 260 G2 Desktop Mini PC i5-6200U Specification for Upgrade or Repair
