Infinity PS-12 Powered Subwoofer Fired Amplifier
  • Asimo5000
    • Apr 2023
    Re: Infinity PS-12 Powered Subwoofer Fired Amplifier
    Great wealth of information on this thread. I was trying to troubleshoot with DMM and I couldn't locate some of the components, I would like to point out some are on the back of the PCB, especially the smallest kinds.
    In my case I have owned this subwoofer since about 2008 (PS12). I didn't have issues until after 2014 I would get a chirp on startup. This progressed to clickiy standby especially in movies where the bass wasn't requested. Fast forward to late 2022 the sub no longer would do anything and would only click.
    Today I spent the day troubleshooting the circuitry, suspecting the big caps were bad as many others did, however voltages all appear to be in check. The only thing I can say with certainty is there is a residue around AC1/AC2/AC3 leads that is sticky, also the board gives off some heat in similar area. Voltages seemed OK, resistance OK, voltage on downstream circuit +15V I measured +14V. I could see a changing voltage (AC) when measuring the output speaker leads.
    In my case, I suspect it actually is the driver. The driver doesn't move or make much noise when using 9V battery. However it is not open loop, and impedance is fine at ~4 ohm. I am not sure how to verify either amp or driver.
    I will see if I have leftover car speakers that I can run off the amp for quick test. Other than that I am not sure what else to do, I no longer have car amps that I can use to test the driver
    Any thoughts?
      master hoarder
      • May 2008
      • 12176
      #202
      Originally posted by Jodeanss
      Should I just start replacing caps anyway?
      I get nothing out of it at all, have never seen the woofer move.
      Yes, start by replacing all of the small electrolytic capacitors, and with good brands if possible. At this age, the old ones are very likely on their way out, given the brand they are.
      Hi Asimo and welcome to BCN.
      Given all the people that have fixed these subwoofers by replacing the small electrolytic capacitors, I would say do this as well for your first troubleshooting step. Just because voltages appear OK on a multimeter does not mean the caps are doing their job. Ripple and noise will not show on a multimeter, nor would the internal leakage of a cap in a signal path (unless you remove each cap and put on a leakage test circuit to verify.) These are usually what tends to kill hot-running subwoofer amp boards. So plan on replacing every small capacitor and some of the medium ones too. Only the big ones are less likely to fail... though not always.
      The driver is easy and you don't need an amplifier for that.
      Just grab a 20-35 Watt 120V (or 230V if you have 230V mains) incandescent/halogen light bulb, or 15-35 Watt corded soldering iron, or even a 10-15 Watt hot glue gun would work. Disconnect woofer driver from amplifier board completely (both leads). Then, using jumper leads, connect one terminal on the woofer to Neutral and the other to one side of the incandescent/halogen bulb mentioned above (or soldering iron or hot glue gun.) Now *carefully* wire the other side/lead/terminal of the incandescent/halogen bulb to 120V AC live (BEWARE that you're working with AC Live here, which can be DANGEROUS and lead to electrocution, so that's what I mean by be careful.) Essentially, you're putting the light bulb in series with the speaker to limit current / power going to the speaker driver so that it doesn't burn out. Once wired up, the circuit will look like this, where "unit to test" corresponds to your speaker driver. At 10-35 Watts (depending on light bulb or soldering iron power rating used), beware that you would get quite a bit of sound and movement from the speaker. In fact, it's a good idea to keep it in the cabinet/enclosure for this test (and screwed in) to prevent bottoming out in free air. Definitely DO NOT use a bulb or iron rated higher than 40 Watts. If this test doesn't make some noise, your driver may be faulty.
      Alternative (and much SAFER low-voltage) test for the woofer driver:
      using a pair of sacrificial / cheap ear buds or other headphones, remove the headphone drivers / buds and use the cord with the 3.5 mm jack to connect the woofer driver directly to your phone or PC (or other device with sound output.) 3.5 mm audio jacks typically have very limited power, so you won't get much sound from the woofer, but you should still be able to hear whatever your playing (alas very mid-range-y and probably muffled-sounding.)
      My personal suspicion is your speaker driver is OK. The amp, I can't say. But with very old electrolytic caps on the board, I'd say the amp is probably OK too, and it's just the old caps causing the issue (hence the suggestion to start with the recap first.)
      • Asimo5000
        • Apr 2023
        Thank you for the reply, I’ll start by verifying the driver since it’s a simpler step before going for capacitors
        To find adequate replacement Caps, do I just need to match the voltage and uF rating? I didn’t see other specs listed on the existing caps
          master hoarder
          • May 2008
          • 12176
          #204
          Sounds like a reasonable place to start.
          The voltage and capacitance (uF rating) are the main parameters, but there are a few more that you may need to match (or exceed in superiority.)
          For starters, the temperature rating: if the original caps are rated only for 85C, then they are general purpose (GP) caps, and indeed matching only the voltage and capacitance (uF) rating is usually adequate. If the caps are rated for 105C, they may or may not be low-ESR type (actually, low impedance.) For low ESR type, you have to check two additional parameters of the original caps: their ESR (impedance) and ripple current (RC). This you can get from the datasheet of the original caps by looking up their brand and series. But beware that this could turn out into a wild goose chase, as some obscure and/or cheap cap brands may not have published datasheets or incomplete data sheets. For the ones you can find datasheets, though, note the impedance and ripple current for each cap type you have. Then make sure the replacement caps have the same or lower impedance/ESR and same or higher ripple current.
          Is it critical to match the ESR and RC rating?
          - No, most of the time.
          This being a subwoofer, the caps are probably regular GP type or "entry-level" low ESR at best... so should be pretty easy to find replacements.
          With all of that said, here's the easier way to go about finding replacements: just use entry-level low-ESR caps for every cap, and it should be OK.
          Since you're in the North America, my suggestion is to order online from reputable websites, such as Digikey or Mouser, and use only Japanese brands (Rubycon, Nichicon, Panasonic, and United Chemicon / Nippon Chemicon), since these are the most reliable electrolytic cap brands.
          Each cap brand has a series. Different series have different ESR and RC ratings. Here are some series from each Japanese brand mentioned, which should be OK for this type of use (amplifier / audio):
          Rubycon YXJ, YXH, YXF, ZLJ, ZLQ, ZLS, ZL
          Nichicon PS, PM, PW, HE, HD, HW, HV
          United Chemicon LXV, LXY, LXZ, KYA, KYB, KY, KZE
          Panasonic FC, FM, FR, FS
          These may also work OK for general purpose 85C or 105C caps:
          Rubycon: PX
          Nichicon: VR, VZ, VY
          UCC: KMG
          Panasonic: EB, NHG, M-series
          And for audio path circuits only (i.e. not part of the power supply filtering):
          Nichicon: FW, FG, KW, KT, KA
          ^ Note that these audio caps may be more expensive. While they are recommended (by cap manufacturers) for use in audio path circuits, they aren't necessary. Any GP or entry-level low ESR series will do OK in audio path circuits too. According to the cap manufacturers, though, these audio caps may be better for the audio quality... but this being a subwoofer, it shouldn't really matter, since you're only dealing with LF (low frequencies.)
          • Jodeanss
            • Dec 2017
            • 7
            Thank you for the reply, I'll start by verifying the driver since it's a simpler step before going for capacitors
            To find adequate replacement Caps, do I just need to match the voltage and uF rating? I didn't see other specs listed on the existing caps
            you can check that sub with any of the channels from the receiver?? I assume your hooking this sub amp up to something? Sub output of receiver? Use any of the 7 speaker outputs on that to test woofer.
            • Asimo5000
              • Apr 2023
              True ! Forgot that can work lol
              Let me check its impedances on my receiver
              • time4this
                • Jun 2023
                PS-10 here with the C71, C72 issues. Thanks to everyone who has contributed to this valuable repository of knowledge! Amazing.
                Has anyone figured out why C71 flames out? What causes this failure mode? I've read through the pages here and don't seem to find anyone elaborating on the causes of this condition. I've got parts ordered to replace, but I'd like to know it is not going to happen again. I'm also going to put a couple air holes to allow some convection (hopefully) to occur. Fingers crossed.
                • CptanPanic
                  • Mar 2015
                  • US
                  #208
                  Just wanted to say that my PS-10 is now exhibiting the clicking after running for a few hours. Any suggestions? Should I just put the spacer to keep things cooler, or should I go ahead and re-cap?
                  • jinu_j
                    How to test Subwoofer Amplifier with only a multimeter
                    by jinu_j
                    Hi Folks
                    Need some advice on how to test a subwoofer amplifier if i have access to only a multimeter.
                    Problem
                    I have a Boston Acoustics active Subwoofer (soundware S). Its rated output is 200W. But the output i am getting is very low i can barely hear/feel it even if put the gain at max. I replaced all the capacitors in the Subwoofer amplifier but still no change.
                    Is there anyway to test this without getting an oscilloscope/Function generator to see if the fault is with amplifier, driver or the source??
                    Any advice would be appreciated...
                    08-29-2024, 02:05 AM
                  • dansity
                    JBL BALBOA 230 SUBWOOFER amplifier oscillating
                    by dansity
                    I'm trying to diagnose this amp but my knowledge run out and need advise.
                    The transistors on the amplifier are rapidly heating up after power on and the speaker produces a wobbly humming noise. I can also measure a lot of weird things on the board.
                    Checks I did so far:
                    • visual inspection for burns, bulged caps and so
                    • speaker terminal measures 0V during operation
                    • checked all transistors for short and voltage drop - they all pass
                    • checked all capacitors nearby transistors as well resistors
                    • no shorts anywhere
                    • Scoped the transistor and I can measure a 5Mhz sine wave on
                    11-21-2025, 10:35 AM
                  • MrCommunistGen
                    Polk Audio RTi100 Plate Amplifier won't power on and intermittently honks and buzzes
                    by MrCommunistGen
                    My childhood best friend was killed about 9 years ago. His parents are finally letting go of his things, and they offered me his Polk RTi100 tower speakers. The Polk RTi100 towers are one of a handful of designs from the early 2000s that is a full range 3-way tower with a built-in self-powered subwoofer. This is accomplished with a plate amp integrated into the speaker input panel.
                    I think they used them for a while, but they've been sitting for at least a few years now. After about 40 hours of driving to their house and back (both they and I have moved in the last 9 years) I got...
                    07-12-2021, 05:11 PM
                  • rustinjust
                    Please help, subwoofer connected to tv, read description below
                    by rustinjust
                    I've got a subwoofer that I've had for nearly 20 years, it did come with a basic remote which I've lost. It's a generic make of subwoofer, I can't see a brand sticker on it. It comes with 2 speakers.
                    Question recently I've connected it up to my tv which has greatly improved the sound on my tv, however I'd like to be able to mute the subwoofer when ads come on or just mute it when the phone rings etc. I tried using a cheap all in one tv remote on the subwoofer and the volume button would only work to increase volume but not turn it down or mute it
                    Is there a way of...
                    10-28-2023, 07:09 AM
                  • rustinjust
                    Please help, where can I get a remote for my subwoofer?
                    by rustinjust
                    I’ve got a subwoofer that I’ve had for nearly 20 years, it did come with a basic remote which I’ve lost. It’s a generic make of subwoofer, I can’t see a brand sticker on it. It comes with 2 speakers.
                    Question recently I’ve connected it up to my tv which has greatly improved the sound on my tv, however I’d like to be able to mute the subwoofer when ads come on or just mute it when the phone rings etc. I tried using a cheap all in one tv remote on the subwoofer and the volume button would only work to increase volume but not turn it down or mute it
                    Is there...
                    10-28-2023, 03:43 AM
