Car stereo USB question
  • stretch0069
    Screwed Up Super Moderator
    • Oct 2003
    • 2658
    • oooo ess aaaaaaaaa
    I just bought a JVC KD-AVX77. Nice little stereo for the pickup.
    I was reading through the manual and it has a warning:
    "Do not start the car engine if a USB device is connected."
    I thought maybe having a USB device connected would initiate firmware update or some crap.
    So I emailed JVC Customer Support and this is the answer I got:
    "I understand that you are inquiring about the USB port of your JVC Mobile stereo. The main reason why the manual is suggesting to disconnect all USB devices while starting your vehicle's engine is to protect the unit (as well as your USB device) from any possible electronic feedback that may occur during the engine cranking process. This feedback will cause any electronic devices to glitch or malfunction over time."
    I don't pretend to know everything....but I can't imagine how a simple thumbdrive would be affected. MAYBE a powered USB device like an iPod, but even then.......
    Anyone have any ideas??? I have a cheap 1GB thumbdrive that I wouldn't care if it got toasted, but I am a bit concerned about the head unit.
    "Its all about the boom....."
    Guns kill people like spoons made Rosie O'Donnell fat.
    We now return you to your regularly scheduled drinking.
    "Fear accompanies the possibility of death.....calm shepherds its certainty"
    Originally posted by Topcat
    AWD is just training wheels for RWD.
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Re: Car stereo USB question
    liability...if you lose your data or your ipod dies you cant sue them
    • yyonline
      • Jul 2009
      • 692
      I'm not an expert on car audio stuff. That said, here goes...
      When you start your car, your alternator starts spinning. This causes a brief surge as your power goes from battery power of ~12.5V to alternator power of ~13.5-14V. The head unit is designed to deal with this, since it's for automotive use.
      Any USB device you have plugged into your USB port may not be designed to handle such a surge. USB power is 5V, but there still may be a brief surge as the circuitry in the head unit compensates for the change in power.
      So, the warning is there for the sake of the connected USB device, not the head unit itself. Is it very likely you'll fry your USB device? I would guess no, but the waning is in the manual just to cover their butt should it happen.
      Edit: Now that I think of it, there's going to be a voltage drop as your starter is energized, and then a voltage surge as the alternator kicks in.
      • stretch0069
        • Oct 2003
        • 2658
        yeah...see...if the thumbdrive dies, its no biggie. Taking what I know about cars and stereos and 'puters......i just can't see the thumbdrive, or any USB device, getting messed up.
        ....hmmm...maybe i'll borrow the digital o'scope and watch the 5v line.....
        • seanc
          • Nov 2008
          • 1319
          When I had my Seat Ibiza, starting it up would cause my iPhone to reboot when it was connected to the car charger.
          Usually only did it after I'd filled the tank up with fuel :/
          • stretch0069
            • Oct 2003
            • 2658
            don't ya just love those "undocumented features"???? sometimes i think there is a bit of "seat-of-your-pants" engineering with electronics.
            • dood
              Deputy dood
              • Mar 2004
              • 2462
              I have a Pioneer receiver with a USB port. I've used it with USB thumb drives, as well as a 1.8" laptop drive hooked up to a USB converter. With the thumb drive, it's been plugged in for about 6 months with no problems. The hard drive doesn't seem to be effected by starting, either.
              The point about the increase in voltage when the alternator starts spinning should make no difference. The USB port is a 5v regulated output. If the HU is sending any power to it at all, it should be 5v or nothing.
              One interesting thing about my HU is that it is a USB spec, and claims to be able to charge iPods and the like from the port while playing. However, if I hook up a 2.5" drive to my IDE->USB converter, it will not spin it up, even though that's the only way the converter works with 2.5" drives. The only way I got a HD to spin up on the converter is to have a 1.8" drive that's in a 2.5" shell with a standard 2.5" ATA connector. I guess it's not capable of as high of a power output as standard desktop USB ports are.
              Ludicrous gibs!
              • alexanna
                • Mar 2010
                • 1346
                Automobiles interrupt the voltage supply to everything except anything that’s needed for the car to start.
                Hell I’m so old I wouldn’t know what a USB dose with a stereo ,But if that’s where it’s getting power from it couldn’t be good.
                Al.
                I should have said interrupted power to accessories
                • kc8adu
                  • Nov 2003
                  • 8832
                  • U.S.A!
                  may get corrupted if it does not get dismounted properly.like pulling one from the pc while it is still being accessed.
                  • stretch0069
                    • Oct 2003
                    • 2658
                    I'm in the same mindset as dood. I haven't put the o'scope on it to confirm, but I'll try Wednesday. I'm guessing there won't be any issue.
                    I does say not to remove when its reading the thumbdrive......but to me, the worst that would happen is the data on the thumbdrive would get horked. No biggie for that.
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 5040
                      • New Zealand
                      If the headunit can't keep a reliable 5v supply to the USB port when engine is starting doesn't that mean it's a piece of junk?
                      -David VanHorn
                      • kc8adu
                        • Nov 2003
                        • 8832
                        • U.S.A!
                        most unnecesary loads are shut off during starting.this includes radio's.cranking while the radio is reading is like pulling it out of your pc while it is reading/writing.
                        might corrupt it but thats all.
                        • Agent24
                          I see dead caps
                          • Oct 2007
                          • 5040
                          • New Zealand
                          Yeah, that makes sense. But this doesn't:
                          Whatever this "Feedback" is - surely the headunit will be designed to prevent against it? I mean, the thing is designed for use in a car where this "Feedback" will potentially occur. If it can't handle the environment it's designed for, then it's not a very good design, in my opinion.
                          They suggest to disconnect your USB drive, well what about the headunit itself? Do you need to disconnect that as well in case of "Feedback"? or does the simple act of removing the USB drive prevent any problems happening to the headunit, as the quote suggests? Sounds pretty weird to me...
                          -David VanHorn
                          • alexanna
                            • Mar 2010
                            • 1346
                            Wonder if the head unit is smart enough to protect itself [shut itself on power interruption]
                            Where the USB is not?
                            Al.
                            • Agent24
                              I see dead caps
                              • Oct 2007
                              • 5040
                              • New Zealand
                              The headunit is supplied with around 12volts from the car - USB devices run on only 5volts.
                              So there will be a regulator or whatever in the headunit to supply the 5 volts to the USB drive, all that will be powered from the headunit, if the headunit's power is cut off, then the USB supply would be off as well.
                              -David VanHorn
                              • beggarmaster2000
                                • Sep 2010
                                hey, guys here is a neat trick for usb audio users!
                                use a usb card reader and memory card instead of a thumbdrive. and noise from your alternator/ac/engine will be eliminated!
                                enjoy music without the hiss
                                • kc8adu
                                  • Nov 2003
                                  • 8832
                                  • U.S.A!
                                  nonsense!only difference is the reader and flash are seperate.
                                  • 370forlife
                                    Large Marge
                                    • Aug 2008
                                    • 3112
                                    Even so I don't get any noise with my radio with a flash drive plugged in.
                                    • Agent24
                                      I see dead caps
                                      • Oct 2007
                                      • 5040
                                      • New Zealand
                                      I think that guy is some kind of spammer probably... well he kinda sounds like one anyway.
                                      Then again if he's the same guy as http://forum.lowyat.net/user/beggarmaster2000 then maybe not..
                                      -David VanHorn
                                      • zen
                                        PS48 Bose sub & head unit schematic / advice please.
                                        by zen
                                        PS48 is model for sub & where i suspect issue lies .
                                        CD head unit seems to run ok , & can take a line out signal into an amp with audio present .
                                        Can't seem to measure any voltages at secondary side of PSU within SUB unit ....
                                        07-08-2022, 07:53 AM
                                      • nzphil
                                        Yamaha YST-C10 stereo capstans run for 10 min when unit is turned on
                                        by nzphil
                                        I have a Yamaha YST-C10 mini-stereo that was made around 1990. It has two cassette decks, a CD player and an AM/FM tuner. When it is turned on in tuner mode, the cassette deck capstans normally run for about one second and then the radio will begin to play. Currently, however, the capstans run continuously for about five minutes followed by running intermittently in two second bursts for another five minutes. The radio will play softly when the capstans stop during the intermittent phase. After about 10 minutes of this, the capstans stop completely and all the stereo functions work fine.
                                        04-11-2021, 05:58 PM
                                      • ngml
                                        Repair of an LG split AC system indoor unit PCB
                                        by ngml
                                        I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
                                        This indicates an error in the communication between the outdoor and the indoor unit.
                                        The outdoor unit is fine, so the problem is the indoor PCB.
                                        The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
                                        I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
                                        Does anybody have the schematics of this board,...
                                        02-01-2025, 12:55 PM
                                      • CoinCoin88
                                        Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                                        by CoinCoin88
                                        I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                                        Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                                        09-15-2025, 03:36 AM
                                      • DynaxSC
                                        Activation of Management Engine after exchange Z590 chipset - ASUS PRIME Z590M-PLUS
                                        by DynaxSC
                                        Hi, i have an ASUS PRIME Z590M-PLUS board, which had an shorted Z590 chipset. I have succesfully exchanged the chipset to a factory new one, however there is a serious problem with the Intel Management Engine (later on: ME) not beeing activated after the chipset device replacement.
                                        For lower chipset families (on ASUS boards) it worked to program the oldest bios version into the SPI rom, and the bios had activated the Management Engine itself by default - there was a message on the screen prior booting - "BIOS is updating Management Engine ..... . Do not shut down to prevent...
                                        06-10-2023, 11:30 AM
