Object: Onkyo TX-NR828
Problem: Overheating / Burned off
Service manual: available
Runs all the years without problems, day on day off. Then all of a sudden with a bang and a small flash one of the final transistors burned out. This is the left front channel. Since the original Toshiba were no longer available, I replaced them all with the equivalent:
Toshiba TTA0001 => 2SC1962
Toshiba TTC0001 => 2SC5242
This also included replacing the thermal paste and the very own insulators with pads (1.3W/mk).
After I now put everything back together and wanted to do a first test, it turned out that the heatsink on the left side (Channels : SBL - SL - L - C - R - SR - SBR ) quickly became very warm. So it is obvious that the burnt transistor was only the result of another original problem. This is the point where I would like to ask you for help. Unfortunately my knowledge is limited / and also a little rusty. Every hint for troubleshooting is welcome.
